Tip & How-To about Cell Phones
Nokia contact service Tricks
Nokia dct4 contact service hardware or software easy to find
NOKIA DCT4 CONTACT SERVICE HARDWARE OR SOFTWARE EASY TO FIND WITH UFS+HWK
1)CONNECT UFS+HWK
2)SELECT DCT4 TAB
3)USE INFO BUTTON(SOME TIMES PHONE NOT ENTER LOCAL MODE JUST LONG PRESS POWER BUTTON
4)CHECK INFO DETAILS
5)SL DATA CORRUPTED(MEANS SIMLOCK ENABLED)
6)JUST UNLOCK PHONE
SEE SECOND PICTURE INFO DETAILS 100%DONE.BUT PHONE STILL SHOW CONTACT SERVICE
7)CONNECT SET
8)RUN SELF TEST
SEE THIS SELF TEST DEIALS
EAR _CLK_LOOP TEST----------NO SIGNAL
RF CHIP ID TEST---------------FAILED
THIS CONTCAT SERVICE HARDWARE PROBLEM
HARDWARE CHANCE
60%UPP
30%UEM
10%OTHERS LIKE BSI ETC...........
SEE ANOTHER SELF TEST DETAILS
LCD TEST-----------FAILED
RESONS LCD MISSMATCHED
JUST CHANGE DISPLAY NO NEED TO FLASH&UNLOCK ETC.............
or alternatively....
SX4: SX4 Smart Card, is a tool or method which is developed by Nokia to
write some data protection for a specific area in EEPROM is useful for
preventing modification of the data.
When SX4 PROCESS is Required ?
In the case of a loss (data corrupt) data charging (not charging), data
network (no network). Dll.RF calibration calibration-charging.
So, all these problems caused by mistakes in the process of flashing or after
write RPL or erase process is done in a certain area
HOW DO I KNOW THAT MY PHONE PROCESS SX4 needs to be done?
When the phone appears CONTACT SERVICE, CONTACT retailers, NOT
charging after flashing, no network, etc. When the SELF TEST is done by
using the box like JAF repair, etc. will be obtained is the result of failed "ST_SECURITY_TEST Failed"
How do I make a SX4?
Plug the phone in the repair box (JAF, MTBOX, MXKEY, etc.)
Write pm area with 309 results read from the normal mobile phone or can
also write FULL PM area without 308 (SIMLOCK area).
What to do sx4 without internet connection?
sure Certificate damaged area musti made first with the FLASH erase, or
write RPL blank
Reset NPC (when using mxkey)
What is a Certificate Area?
Press info on the box like JAF flasher, etc. and see the results LOG ...
This is an example of the correct Certificate
Default SN type:
Code:
IMEI plain: 351862xxxxxxxxxx
IMEI spare to net: 3A 15 68 02 01 23 60 03
IMEI SV to net: 33 15 68 02 01 23 60 03 F6
LOCK STATUS:
Config KEY: 0000000000000000
Provider KEY: 2440700000000000
Provider: AT &T; U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
This is an example Certificate of damaged
Default SN type:
Code:
IMEI plain: 123456765321?
LOCK STATUS:
Config KEY: fffffffffffffffffffffff
Provider KEY: fffffffffffffffffffff
Provider: Unknown
Block 1: Lock 1: CLOSED
Cell Phones Logo
my cell phone of nokia 1110i software is goes to defect so now i want again install the software in mibile nokia1110i
There is no other way to solve this because nokia DCT4 cannot flash via USB if it is usb supported phone i'll definitely help you via internet. So the best thing is to contact mobile repairing shop.Good luck
Jul 25, 2011 | Nokia 1110i Cellular Phone
1202 nokia dead from water falling whaen i flash
hi,
clean your unit first using lacquer thinner,then blow it slightly by hot air...after doing that clean the pin out because if it water damage it must be corroded...what version of jaf you are using?if your version are not updated ,1202 is a sl3 (simlock 3) unit and not supported by lower version of jaf...much better if you use mx key dongle and ufs box as your interface (do not use jaf as your interface because it would be damage) or cyclone....and here is the procedure..
using easy cable ,connect the phone ,open mx key module ,select ufs interface ,dct4 then bus check...if the info of unit is showed ,put CNT ,MCU,PPM ..before flashing back up your phones rpl first ...then flash the phone...after flashing ,there is a possibility that the phones status is contact service ,dont worry just go to service ,imei and security then direct unlock...but be sure that your mx key is activated by dct4 plus unlocker...
in case the phone is not responding after cleaning ,reheat flash ic then repeat the procedure...i hope it will help you ,thanks for trusting fixya..
goodluck..
Jun 16, 2010 | Cell Phones
I NEED SECURITY RESETTING CODE FOR DCT-4
You can get master code for the specified DCT4 model from the following link
DCT4 1100 1101 1110 1600 2300 2600 2650 3100 3120 3200 3220 3510 3510i 3650 3660 5100 5140 6020 6021 6030 6060 6070 6080 6100 6101 6103 6170 6111 6220 6230, 6260 6310 6310i 6510 6810 6820 6822 7200 7210 7250 7250i 7260 7270 7280 7360 7600 7610 7650 7700 8310 8800 8910 8910i
http://www.unlockme.co.uk/master.php
Please rate this solution
Rnj VINODKUMAR
Oct 15, 2009 | Nokia 2310 Cellular Phone
Contact service
Maybe the hardware got wrong. Better u try to reset the software by restore factory setting. def password : 12345
Jan 22, 2008 | Nokia 1600 Cellular Phone
contact service
hi there you must go to your nearest service center to reprogram your phone.
peace!
Dec 15, 2007 | Nokia 1100
602 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
