Tip & How-To about Cell Phones
To detect your lost phone
Install antitheft in your mobile and give your another two numbers in ti when it is lost . they started using it you will receive the the message from the number
Cell Phones Logo
I have lost my phone in the train and i don't have any anti theft app installed in it. So, how can i find my android phone ?????
You just go to the police station and give there an application for stolen phone, the police department has survilance system which can track your mobile easily, whether you had an antitheft system on or off doesnt matter... recently i have read that there was somone whose phone got stolen but survilance department found that... best of luck...
Jan 10, 2015 | Android Cell Phones
I have lost my samsung corby. I have activated the mobile tracker. Remote phone is my wife's. Now we are receiving message with a phone number being used in the lost phone. How to proceed? whether the culprit be tracked down. should file an FIR
I would believe it would be best to contact the authorities with this information, this way you can have a police report and have that report to give to your service provider which will further on with the investigation. It helps a lot more that you have used mobile tracker.
Feb 28, 2011 | Cell Phones
hello, when i try to put some teks on my TI 84+ he gives an error
Anything you enter is interpreted either as a number or a command. if the calculator does nor recognize what you write as a number or a command it gives you an error message.
If you want to use your calculator as a text editor ( a very poor one at that) you should download and install the NoteFolio application. It may already be on your calculator.
To download applications go to this web page
Jan 18, 2010 | Texas Instruments TI-84 Plus Calculator
I received this solution, but at the end the calculator asked me about some invalid certificate. Now the ti 89 is stuck at the boot screen because if I retry, it goes thru the whole process again and asks for the certificate. If I skip, it wants to restart at the boot screen. what now? It is a regular ti89, not titanium. that was the only choice available. Solution #1 posted on Oct 31, 2009 k24674 Rank: Guru Rating: 86.66% , 474 votes Hello, Here is what the FAQ and Knowledge Base area of the TI site has to say about the problem you are having. Hope it helps. How do I correct the error message ''TI-83 Plus or TI-89 detected, but could not get status'' using the TI Connect software for Windows®? The Operating System (OS) will need to be updated on the TI-83 Plus family or TI-89 calculator in order for the TI Connect software to detect the status. Try the following procedure to install the OS from the TI-83 Plus and TI-89 Boot Screen. Make sure TI Connect 1.6 is installed on the PC. If using a TI-89 calculator: ? Connect the TI Connectivity cable to the TI-89 calculator and the computer. ? Do not start the TI Connect software. ? Download the TI-89 v2.09 OS onto the PC's desktop. **Force the TI-89 into the ''Boot screen'' (see instructions below)** ? ''Press I to install...'' (press the [9] key). ? Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader. ? Follow the on-screen directions to install OS version 2.09. The download should begin. **Steps for Boot Screen:** ? Take one AAA battery out, press and hold down the [APPS] key while reinserting the battery to force device into the Boot Code screen. ? ''Press I to install...'' will appear. Once the OS has completed installation, the TI Connect software will be able to detect the TI-89.
The answer I gave you was taken verbatim from the TI FAQ and knowledge base. I copied and pasted the part relevant to you calculator.
In any case, I sent an e-mail message to ti-cares@ti.com, giving the link to your original question and my answer to it. I took the liberty to copy/paste your present message. I also asked about that invalid certificate.
All we can do know is wait for their reply.
k24674.
Oct 31, 2009 | Texas Instruments TI-89 Calculator
motorola razr v3 can receive text messages but cant send.. help just bought on ebay new and unlocked for att or t- mobile..
Call ur service provider's customer care help line . Ask for <message/service center number>.Then go to ur phones message option>click the center -- key> then goto the message setup> text message setup> service center no...>
Change the no. with the number given by the customer care and then click <Done>. come out to the Home screen > restart ur phone
Dec 07, 2007 | Motorola Mobility RAZR V3
225 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
