Tip & How-To about Computers & Internet
HOW TO FIX YOUR GENERAL PC ISSUES
Hi readers this contents lets you through the way of how to know,verify your general PC problems and how to fix it on your own without wasting much time and also saving your money.Money and time are of course the two most valuable things that you should not waste unnecessarily,many people are beginners and learners and its common when you do something wrong you learn something from it and avoid repeating such mistakes in future.Today i am going to discuss the most frequently asked queries about the PC problems.
INTRODUCTION:Modern PC's are certainly marvels of technology and yet,for all their advances,computers still do crazy,inexplicable things.Even so there are a number of common issues you can diagnose fairly easily.Some of these are what seems like idiocy on the part of PCs like Why does my PC shut down without warning me?.Others occur when new hardware or software is introduced to your system which doesn't play well on your existing setup well to fix these problems you should know your PC to the fullest of the extent.Knowing your system thoroughly is like knowing your best friend because it helps you a lot.
GENERAL FAQs:
I need some help from my PC.Where do i start?
Click the Start menu and choose Control Panel,'SYSTEM AND SECURITY'.Select "Review your system's status".Here Windows will alert you to any security issues or other problems that it thinks you need to address.At the bottom of the screen is an option labelled "TROUBLESHOOTER".Click this to explore further options.your system is the guide to your problem,for every problem the solution lies in itself your "Troubleshooter" helps you often how to solve the particular problem it is pre-enabled in windows itself.
My Friend is happy to look at my PC.Should i let them?
First check whether your system is out of warranty or not.Some tinkering and Hardware upgrades will void it.Then,if your friend is trustworthy enough to let loose near potentially sensitive files and confident of your repair abilities then let him take a look at them.Save your friend some time in trouble shooting the problem by providing a full fledged details of the problem when it started,what you were doing when it started,as well as the make and model of the machine and the inventory of the hardware installed on your computer.If you are unaware of your systems hardware you can find it for yourself by going to the Start menu->my computer-->system and properties or you can also right click on the My Computer Icon and select System and Properties.Within System Properties you can view what hardware your machine is running,Windows product key--invaluable should you ever need to reinstall the Operating System(OS) for e.x. Windows XP or Vista etc., and how well your system is performing.
How can i describe what's happened to my PC?
Problem steps recorder is invaluable here.Type it's name in the Start menu--->Search box and a macro recorder will appear on screen.Use this to show what has happened.
Any tech support or Computer Savvy friend may want to know the symptoms that may indicate when the problem occurred and what it may stem from.Note that most faults are caused by "inadvisable software installations". But before you draft in the backup,try a "System Restore". This acts like a time machine,returning the computer to an earlier state,such as before you installed any faulty program,it may well fix your problem.To attempt a system restore
follow the below given steps:-
  1. Go to the Start menu----> select Control Panel.
  2. In the Control Panel---->select System and Security.
  3. After selecting the System and Security menu select either find and fix problems or type System Restore in the search field at the top right.
A calendar highlights in bold the days when System restore points have been created.Ensure that you select a time that predates the time when the problem had occurred.Follow the prompts to allow windows to perform System restore.
With these helpful tips i take my leave here till then keep waiting i will be soon looking forward to provide you more helpful tips in the near future.Thanks a lot viewers for reading my content and do make sure to implement it so that you learn to fix your problems on your own and get the most out of you PC.If you liked my content featured and do want to ask any queries or to give any suggestions and feedback please feel free to contact me on my ID bonefirediv@gmail.com .Thanks for visiting fixya and making a part of your life and please rate my content if you felt it useful and if you liked it.
With warm regards- bonefirediv.
Computers & Internet Logo
I want user manual for SGH-T959
http://www.samsung.com/us/mobile/cell-phones/SGH-T959ZKATMB Click the "I own this" button then click the "get the downloads" link and you're good to download all the guides!
Feb 28, 2011 | Samsung Vibrant T959 Crystal Silicone Case...
My phone always hang-up after i received / accept a call, In addition speakerphone features does'nt work for every call.
This problem due to virus.
Restart your phone, scan your memory card with an updated antivirus (on your computer using a memory card reader) or if possible format the memory card after files are backup.. This will definitely fix you issue. You can try without the memory card and verify whether the problem persists or not.
Let me know if this doesn't help.
Good luck.
Feb 24, 2011 | Samsung SGH-S5230 Cell Phone
card reader not working
Hi
if you follow this link www.acer.com go to support/downloads type in your make model and operating system eg xp or vista or windows 7 then look for card reader driver and download it
this should fix the problem
if not please post up again and we at fixya will try to help you
good luck
please let us know if fixya fixed it for ya
Jan 25, 2011 | Acer Aspire 5630 Notebook
I need an instruction manual for hi-fi CMT CPZ3
You can download and print the instruction manual for CMT CPZ3 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Jan 22, 2011 | Sony CMT-CPZ1 Shelf System
Free Instruction manual for the Asus K50 Notebook
Here it is (click here), it's a pdf file zipped inside a Winzip file, you'll need winrar or winzip program to extract the contents (the pdf file). And also, you'll need a pdf reader, like Adobe reader or Foxit Reader to open the file (manual) on your computer.
Click here to download Winrar
Click here to download Adobe Reader.
If you need further help, let me know.
Good luck.
Oct 13, 2010 | Computers & Internet
203 people viewed this tip
David Payne
David Payne
