Tip & How-To about Cameras
Lens Error fix for Digital Camera
One of the mostcommon digital camera error messages has to do with a lens problem.Some cameras will just beep and not show any error message and otherswill have an error message on the LCD screen. Some camera's will try tostart, the lens will go out and then return back and shut down.Sometimes nothing at all will happen, but the lens is the reason whythe camera will not start up.
Different camera'smay give you different error codes. Some of the error codes will beE-18 for older Cannon camera's, ACCESS error for Sony, Zoom Error forFuji, lens error restart, or just plain lens error. These are themost common camera error messages, but your digital camera may have a different one.
There are manydifferent things that can cause the lens to give an error message.One of the most common causes is keeping the camera in a case or bag.The dust, grit, felt, and lint from the bag gets into the cameralenses and causes it to jam. The static electric from the camerarubbing the side of the case causes the dirt to be attracted to thelens, which makes the problem even worse. Also if your camera is in acase and the button gets pushed to turn the camera on, and the lenscannot extend it can cause the lens pins to come out of the track,causing focus problems and lens errors. Bottom line is that you areoften better off not keeping your camera in a case! It is saferwithout a case then with one.
The next problemthat many people encounter is that they drop or knock the camera withthe lens out. When this happens, the lens pins can come out of thetrack, and/or the lens can be knocked sideways, which will jam thelens as it tries to extend and/or focus and zoom. If you do drop orbang your camera against something, there is about a 50/50 chancethat it can be fixed. Many times with care the lens can be realigned,but in some cases the jarring or the realigning, will break somethinginternally, so there will be no fix for it.
If your digital camera hasa problem, you will have a couple of choices. You can try to fix ityourself, or you can try to find a camera repair shop that will fix it for you.Because of the type of problems that cause lens errors, the digital camerarepair will seldom be covered under the manufacturer warranty. Alsobe careful to get a quote from a digital camera repair shop before youauthorize the repair. Many times the repair price quoted will be morethen the replacement cost of the digital camera. If you do a search on theinternet for a camera repair shop, make sure to include any shipping andhandling costs in the repair price.
If you choose totry and repair the camera yourself then look for my tip - Steps toRepair a Digital Camera Lens.
This gives you thehow and why of your digital camera error message, and/or why your digitalcamera will/may not start up.
Steps to Repair a Digital Camera Lens
How to easily download Pictures from Digital Camera
How to Unlock SD Card
Digital Camera Manuals, Drivers, Downloads, and Support
Cameras Logo
camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
canon ixus 60 - lens error restart, restart camera
Dear God, It was like a comedy. I got on the whale boat, after having the Canon ixus 60 for 4 years. I've never had any error messages. The whales came 10 feet from the boat and twice raised their head, and no camera, just the beeping and the error message: lens error; restart camera. How do you restart the ixus 60 Canon digital camera, anyone? Please help!! Thanks Claire@klarity.org, Maui, Hawaii. Aloha!! & Mahalo.
Aug 26, 2009 | Canon Cameras
PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens error. Restart camera.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 07, 2009 | Canon PowerShot A720 IS Digital Camera
24,696 people viewed this tip
Top Cameras Experts
Marvin
Marvin
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Camera Expert? Answer questions, earn points and help others
