Tip & How-To about Computers & Internet
How to format the hard disk ? here are the ways
What is hard disk? hardisk is an internal storage device by which we can store the data and also get back the data when we needed. hardisk is like a grama phone. you can create a partition on it also. so here are some tips how to format your hard disk. 1) plug in your hardisk by a external cable and wait for while to install the drivers . and then just double click on my computer and right click on the drive letter which you want to format and then hit format. now you have a option there select ntfs and defail and you have one more option called perfome quick format . if you click on this the formating will done quickly . and then start. done.
2) right click on my computer goto manage goto disk management and there you can see the drive letter just right click on it and format it . you can also remove the partion or create partion from there.
3) insert the xp boot disk and follow the instrucktion and after that you will get an option to select drive . just click on it and hit format . you have two types of formating ( quick) and full.
4) insert the win98 boot disk or insert hiren's boot disk and then go to dos ( for hiren boot disk only) after you completly boot from cd rom then you have an A:\ drive . this is called RAM drive. just write the command FDISK and hit enter and then Y and hit enter and then 4 to display partion. you can create a new partion from here also. after making any kind of changes you have to restart the pc . after restarting A:\ will appear. write down the command FORMAT C:\ and hit enter and Y thats it.
there are many ways to format your drives. there are lots software also available in the market to format it. but the best way is 4) because it do the slow formating and also recover the allocation unit.
Computers & Internet Logo
How to export recorded video on a Pelco DX8100 DVR?
Converting Pelco exported video files
WHAT IS A DVR?
A DVR is a video recording and pl
ayback device that inco
rporates all of the essential capa
bilities of a VCR but adds significan
t advantages. Like
a VCR, video is recorded from one or more cameras and stored for later playback and retrieval; however, in a DVR, video data is
recorded and
stored on a hard disk instead of
magnetic tape.
Storing video in
this manner facilitates
instant, rand
om access to data, as opp
osed to sequential
access inherent to tape-based recording. This means no fast-forwarding or rewinding is necessary to locate the data a user want
s to view or
export. Another key advantage over tape is decreased maintenance. With no need to replace tapes, DVRs with hard disks can be le
ft unattended
for extended periods of time. Since video remains in the digital domain, data is easy to store, transport, and manipulate. Unli
ke analog video
recordings, digital data does not suffer from a loss in quality wh
en copied or moved from device to device. Because DVRs rely o
n hard disks
instead of tape, data storage is virtually unlimited. Video data
can also take advantage of comp
ression technology
to increase
the efficiency of
storage media. Modern DVRs, such as the DX8000, allow users to record, play back, and view live video simultaneously. Keeping d
ata digital
means video can be easily backed up to a variety of storage media.
It also means that alphanumeric
information, such as date, t
ime, and
transaction statistics,
can be synchronously recorded with video.
Jun 20, 2015 | Pelco Televison & Video
My hardisk showed 2000-0146 error and it got replaced with new harddisk.. can i recover data from my old harddisk?
Try connecting the hard drive to an USB hard drive adapter and connect it to a computer's USB port. The computer should see it as an external storage device and you can open the various folders and files to backup your data.
If the computer cannot detect the hard drive as an external device then the hard drive is faulty.
If the hard drive makes a clicking noisy then it is definitely faulty and replacing the circuit board cannot fix this problem.
There are companies that can retrieve data from a faulty hard disk BUT it will cost you an arm and a leg for their services.
Jan 24, 2011 | Dell Latitude D630n Notebook
where is info stored on a external hard drive
An external data-storage device has a few parts:
* a USB cable
* an enclosure
* a disk-drive, exactly as used inside a desktop or a laptop
* a USB-to-disk-drive adapter
So, if you open the enclosure, you can see an "internal" disk-drive.
You could even disconnect the disk-drive, and then connect a much-larger disk-drive,
in order to increase the capacity of the device (and to replace an out-of-warranty disk-drive
by a new in-warranty disk-drive).
Oct 24, 2010 | Maxtor Hard Drive
computer doesnt detect chrashed harddisk so that to recover data
Your going to need a technician that specializes in hard drive data recovery.
Nov 19, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
278 people viewed this tip
David Payne
David Payne
