Tip & How-To about Computers & Internet
General computer repair
Even if you think you are sure of the source of problem with your machine/computer, it is always advisable that you back up your data, and follow the available troubleshooting techniques to make your data safe for just in case...and to know of any other unnoticed problem respectively before jumping into the solution. This may help you be sure that your data is safe and your solution will work perfectly. Because otherwise, even the solution you thought would work wont because of failure to do this.
Computers & Internet Logo
hard drive does not operate
1, switch off computer
2. remove side (usually two screws on the back held it)
3. remove and then re-insert power cable from hdd
4. remove and re-insert data cable, from hdd as well as from m/b
5. start computer and hold your fingers on the top of the affected hdd, if you feel vibrations, this meant that driver is spinning and therefore rescue can be attempted at home.
6. research and purchase hdd recovery software, follow it's instruction and save data on another medium, be it another hdd or cd's dvd's.
if there is no spin, recovery is still possible but in specialist lab and will cost more money....
always back-up your data, second hdd is much cheaper than data recovery from existing one...
Jul 27, 2010 | Maxtor Hard Drive
My 7kg samsung washer always flashes error code 4E now... please give me the solution...
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 04, 2009 | Electrolux EW1200i Front Load Washer /...
inlet tube on washing machine
Jan 21, 2009 | Washing Machines
Blue colour spread
  1. Reset the projector to factory defaults,Change sources. Try plugging the projector into another computer.If the color problem persists, check the cables for bent or broken pins. If any pins are damaged, the cable will need to be replaced with an InFocus-approved cable.
  2. Upgrade the projector firmware. If the projector still will not display the image, it is possible that there is an internal problem that requires repair.
Jan 18, 2008 | InFocus ScreenPlay 4805 Multimedia...
always sending multimedia
Yes, it is notorious virus of com warrior family. You are advised to format it immediatly otherwise it can harm your RAM by keep it busy. It is necessary to format phone and MMC (Media Card) both. Card can be formatted in computer and phone with simenteniously pressing four keys----those are *,3,Green send key and forth one power switch. Backup important data before formatting. Don't upload backed--uped data untill disinfected by any good virus programme in PC.
Jan 16, 2008 | Nokia N70 Cellular Phone
189 people viewed this tip
David Payne
David Payne
