Tip & How-To about Computers & Internet
PC Tools- Maintaining Your Computer's Performance
Maintenance Tips for Maximum Performance
With the amount of information available for download on the internet, it's easy to quickly fill up your valuable hard drive space and turn your computer into a sluggish, unresponsive monster. Keeping your hard drive clean is essential to the high performance that the latest computers can achieve. Fortunately, it's a simple process; one that can easily be performed on a regular basis and, with some organization, keep your computer running like a well-oiled machine.
You can discover how much hard drive space is available on your computer by accessing the DriveSpace program in your System Tools. A pie graph will show you the amount of used and unused space for each of your drives. Check this often to keep an idea of how much space you are using.
There are six simple steps to clearing up your hard drive:
1. Uninstall unused programs.
Many times a new program will come along that looks fun to have or play with, but after a week or two you simply stop using it. These programs clutter up your drive and take up valuable space. You might be tempted to delete these programs from your drive, but doing so will cause problems. You must use the uninstall function of Windows for the program to be removed safely and completely.
2. Clean out temporary files.
When your computer is not shut down properly, it will pass information from memory into fragmented files. Also, while you are running programs, your computer will write information that it does not immediately need into temporary files. Installation files will also expand themselves into the temporary folder and will not always clean up after themselves. You can delete these temporary files safely by using the Disk Cleanup option in your System Tools.
3. Empty your internet cache.
As you surf the internet your computer stores web pages and images into a temporary internet cache so that it can quickly recall and access information when you move back and forth between pages. This backup information can quickly add up and eat hard drive space.
Whether you use Internet Explorer, Netscape, or one of the many other browsers available, emptying out your cache is quick and easy. Simply follow the instructions in the Help files located within those programs. You may also wish to set a specific maximum file size for your cache folder, so that it is not allowed to run rampant.
4. Empty your mail programs of clutter.
It's easy to browse through your email and leave old messages there, promising yourself you'll sort them out later. One or two messages don't take up much space, but hundreds certainly do. Take the time to sort through these old emails now and delete what is not important. Create folders and organize what is left. Make it a habit that when new emails come in, they are either filed immediately or thrown away. Set your email program to empty your deleted items folder each time you close your mail program.
5. Empty your recycle bin.
Once you've emptied your drive of cluttering, unecessary programs; empty your recycle bin to remove what has been placed there in the process.
6. Scandisk and Defrag.
When Windows installs programs, it will put the files it needs anywhere that it finds free space, and not directly after the last program installed. As a result, your hard drive has patches of empty space on it that are not big enough to fit a full program, and will result in a drive space error if you attempt to install something new. Scandisk your drive to check for lost file fragments and to fix any errors it finds, then Defrag to pack all of the program files together at the beginning of your drive. This will clear out those empty patches and move all of the free space you've just created to the end of your drive.
Now that you've got it clean, keep it that way. Perform this quick maintenance routine every week. For your work computer, Friday afternoon before you leave for the weekend is the perfect time. When you return to work on Monday, you'll have a computer that is clutter-free and as responsive as it should be.
Organize your surfing habits. Direct all of your downloads to the same folder, so that you can easily find them and delete them when necessary, or move them to zip disks for storage. Keep track of the programs that you install. For trial versions, note the date that they will expire on a calendar. This will remind you to uninstall the programs that you can no longer use rather than allowing them to clutter up your drive. Also, if you run into problems, keeping track of new downloaded and installed programs and the date they were installed can help you track down the cause of problems.
Remember that the cleaner your hard drive is, the better your machine will respond! In order for your computer to be user friendly, it must have a friendly user. Be your computer's best friend and clean out the cobwebs regularly.
Computers & Internet Logo
I neeed a USER Manual for ACER MB.SE109.002 Aspire Desktop Board Motherboard
I believe what you are asking for, is a Motherboard Manual, for the motherboard used in an Acer Aspire M5400 desktop computer,
Not available.
The motherboard is made FOR Acer, by a motherboard manufacturer.
In this case the manufacturer does not supply information.
Acer does.
Motherboard,
http://www.shopping.com/acer-acer-mb-se109-002-aspire-desktop-board-motherboard/info
Specifications,
http://support.acer.com/acerpanam/desktop/2010/acer/Aspire/AspireM5400/AspireM5400sp2.shtml
With the above information you can see;
1) Processor Support.
2) Uses a Socket AM3 processor socket,
http://en.wikipedia.org/wiki/Socket_AM3
[ Look at the list of AMD Phenom II, and Athlon II, processors.
Now look at this chart, {Scroll down},
http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors#Phenom_II_series
Now look at the processor socket used for these processors. Scroll the page down, compare using the charts ]
3) The motherboard chipset is an AMD 880G,
http://en.wikipedia.org/wiki/List_of_AMD_chipsets#A-Link_Express_III
Here you see more information on what the motherboard supports.
4) The Ram Memory used is DDR3 Sdram, at either 1066MegaHertz, or 1333MHz.
(That is PC3-8500, and PC3-10600, respectively)
The Maximum TOTAL Amount for the motherboard is 8GB.
There are 4 Ram Memory slots.
The Maximum Amount for EACH one is 2GB.
NOTE*
O/S = Operating System.
Windows XP, and Windows 7, are two examples of an O/S.
With a 32-bit O/S, the maximum amount of Ram Memory that will be recognized, is 3-1/2 GigaByte. (3.5GB)
You have to have a 64-bit O/S for above 3.5 GB.
(8GB? You need a 64-bit O/S)
ALSO, don't just use any Ol' DDR3 ram memory.
I doubt you can go into BIOS Setup, and change the Voltage, and ram timings, for a high-performance ram memory.
In otherwords 'gamer' ram memory.
JEDEC sets a standard for Ram Memory.
One of the standards is the Voltage. Standard default voltage set for your motherboard by JEDEC, for the Ram Memory, is 1.5 Volts. (DC)
MAXIMUM voltage is 1.575
That Acer board is not capable of handling DDR3 high-performance ram memory, that will exceed 1.5 volts.
(Probably isn't a BIOS upgrade either)
What is it that you seek? Post back in a Comment.
Regards,
joecoolvette
JEDEC,
http://en.wikipedia.org/wiki/JEDEC
May 19, 2012 | Computers & Internet
avira anti virus can't install
Un-install Avira Anti-virus Then Download and Scan By Using Glary Utilities
Optimize, clean and boost the speed of your Windows.
Protect your privacy and security.
Block spyware, trojans, adware, etc.
Fix certain application errors.
Simple, fast and User friendly interface
For only private use One Click A Day For PC Maintenance, Keeps Any PC Problems Away. With millions of worldwide users, the first-rank & free Glary Utilities is an INDISPENSABLE friend for your PC, with its 100% safe, thorough & quick cleaning and worry-free restoration.
Glary Utilities is a freeware with registry and disk cleaning, privacy protection, performance accelerator and amazing multifunctional tools. It can fix dogged registry errors, wipe off clutters, optimize internet speed, safeguard confidential files and maintain maximum performance.
The era of PC vex is dwindling as Glary Utilities comes. It is a freeware with registry and disk cleaning, privacy protection, performance accelerator and amazing multifunctional tools. It can fix dogged registry errors, wipe off clutters, optimize internet speed, safeguard confidential files and maintain maximum performance.
It is designed for both novice and professionals. User-friendly interface shows clear & detailed directions. For novice, all work can be done with just 1 or 2 clicks, while for professionals, abundant options are available.
To call Glary Utilities helpful would drastically understate the situation. It hopes to become your INDISPENSABLE friend with its one-stop-shop utilities for optimizing and maintaining your PC for best performance. My friend, welcome to have a try for Glary Utilities and have your say! To download Glary Utilities Press here http://download.cnet.com/3001-2239_4-10322935.html?spi=b1d949f58a45ea56498a7664cb708430
Download by Using ATF-Cleaner.exe was once upon a time just my personal temp file cleaner. There became a need for a good temp file cleaner that could do the job safely and without removing files that are crucial to windows, so I decided I'd share it with the public.
ATF-Cleaner has recently picked up alot of interested in the various communities online.
ATF-Cleaners options are fairly straight forward and its simplicity is part of its charm.
The general instructions for its use on the forums are as follows:To Download ATF-Cleaners press here http://www.atribune.org/index.php?option...
then Restart you Computer,after you Computer it is open Windows Now Download Again Avira Anti-Virus Press here http://download.cnet.com/3001-2239_4-10322935.html?spi=b1d949f58a45ea56498a7664cb708430
Jan 03, 2011 | Avira AntiVir Personal - Free Antivirus
how to increase virtuall memory
For Win XP;
1.Click Start, and then click Control Panel.
2.Click Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click Settings.
4.On the Advanced tab, under Virtual memory, click Change.
5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click Set
When you are prompted to restart the computer, click Yes.
Special Note: You should choose the same amount for the initial size and maximum size. This will Stop your CPU from constantly changing the paging file.
Aug 10, 2010 | Computers & Internet
373 people viewed this tip
David Payne
David Payne
