Tip & How-To about Computers & Internet
PC Tools- How to clean your computer
  • Cleaning the Computer
If you've noticed that your computer's keyboard feels sticky or the monitor screen appears spotted under the light, it's time to clean these pieces before internal damage occurs. Cleaning your computer's keyboard does not require special knowledge or skill. But you should take precautions to avoid damaging the internal parts when caring for the external hardware.
1. Unplug the computer and all accessories before getting started. Anytime you attempt to clean an electric appliance it is important to disconnect the power source to reduce the risk of electrocution or shock. After unplugging the keyboard and monitor, along with any accessories that may be plugged in, use a damp clean cloth to wipe all the cords that are connected to the monitor and keyboard and remove dust balls or hair, along with anything else that might cling to them.
2. Move the computer monitor and keypad to one side of the desk and wipe the area clean where the equipment usually sits. Be sure to wipe a large parameter around the monitor area and let it air dry completely before returning the keypad to that area. You might want to use a clean towel or dry cloth to rub over the desk to be certain it is dry, as dampness can damage the machinery or cause it to stick to the table's surface.
3. Rinse the damp cloth in clear hot water and wring it nearly dry. Gently wipe the monitor screen, including all the corners, to remove dust and spots. Then wipe the surrounding areas and framework of the monitor, including the indicator lights that show when the system is operating. Don't forget the back of the monitor as well. If you have a laptop computer with a top that folds down and closes, wipe the hinges carefully, using a cotton swab for grooves and the latch. Check the latch to see if it is sticky or closes readily.
4. Next, go over the keyboard with the cloth, lightly rubbing around each key and button. Wipe around the sides of the keyboard, catching the off and on switch and CD player. Then use a cotton swab to ease around the edges of each key and row to retrieve minute amounts of dust and crumbs. Carefully clean around the lights, plug openings, and speakers, as well as other areas of your computer. Check to be sure you are not leaving wet traces on the equipment, as this means your cloth is too damp and should be wrung out more.
5. Allow the machinery to air dry, or use a soft cloth to pat the keyboard and monitor dry. Don't use fabric with lint or that is tough enough to scratch the screen. Reassemble all the cords and parts when you are sure the entire unit is clean and dry.
Plan to clean the keyboard and monitor every month or two. You may want to schedule maintenance for an interior cleaning once or twice a year. A clean computer is more likely to work well and last longer.
Computers & Internet Logo
I spelled Juice on my HP Pavillion g6,, i dried it , but keyboard are sticky and screen has a white spot, whiter than the rest of the screen
The screen is probably permanently damaged... Some of the juice got into the screen which is bad news. You have to be very careful with liquids around laptop screens, even when your just cleaning it. You should never spray or spill anything on a laptop screen. So if it bothers you too much you'll probably want to bring it to an expert to be replaced.
As for the keyboard you can clean it easily with a damp/wet cloth while it's turned off and the battery removed...
May 13, 2012 | HP Computers & Internet
Dark blue ink splodge on my computer screen
Check the warranty - I recently got an acer lcd from a friend (purchased as package deal like a eMachine), he bought a new one, and found it was still under warranty.
Try "Auto Reset" on the monitor setup panel, on monitor - not on computer.
I forgot the proper name but one of the light emitting diodes might have gone bad which causes lines, streaks and blobs (same as on laptop screens).
Apr 04, 2010 | Computers & Internet
I spilled soda on my keyboard, and now the keys are sticky. How should I go about cleaning it?
u can get a can of IPA cleaning fluid from your local hardware store or use vodca or a nother alchole. unplug the keyboard first. :)
Dec 01, 2009 | HP Compaq 1701 17" LCD Monitor
Black spots on the screen
I think you should try going to the store and checking if your monitor is still under warrenty. From the description, I think it is beyond repair.
Jun 26, 2009 | Samsung Computers & Internet
Menu keeps popping up; Stuck buttons perhaps?
Yes, a stuck key would be a likely culprit. Sometimes a key will get stuck out of just plain useage/wear, or, pop or other liquid spill or splatter will result in a sticky key. Press on the suspect key-compare to another key- different feel will tell you a problem exists.
Low cost keyboards don't generally have the life expectancy as older higher quality ones. Laptop keyboards are also more fragile, and subject to problems.
Dec 23, 2008 | Dell E153FP 15" LCD Monitor
1,365 people viewed this tip
David Payne
David Payne
