Tip & How-To about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Shark steam mop not producing steam
It is a design flaw having a check valve orifice built into the steam generator.
The plastic sleeve gets hot and get hard and shrinks enough to cause blockage at the inlet to steam generator.
Also a lot of sediment builds up inside steam generator from impurities in the water which eventually causes a problem and block at the mop head.
solution would be to move the check valve from the steam generator to the pump discharge line where it is cooler. and use only distilled water. they should also use a stainless heater element instead of pot metal as it corrodes.
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
Haan sI70 unit gets hot but no steam is generated, so not hot enough. Anything I can do?
It sounds like the internal temp thermostat is detecting that its hot enough when its not, and cutting the power as its supposed to, but too early. It may not be worth time/effort/money changing this part, in case its a problem with another part. Its a bit desperate but you could turn it off and half fill it with cold water then shake it vigorously to see if washing the internal surfaces impoves things.
Dec 15, 2013 | Haan SI70 Multi Sanitizing Floor Steam Mop...
The roll brush will not turn when on floor. Too much pressure stops brush. Changed belts and still not working
Turn the belt inside out. This problem stems from a design flaw in the mechanism that turns the hoover from bare floor to carpet. After taking it apart I realized that the spring that pushes the belt tight (to make roller spin) is not any where near strong enough to keep the brush rolling. My solution was to turn the belt inside out (there by essentially shortening the belt and allowing enough pressure to be applied to the roller to keep it spinning. Horrible design flaw. I am an engineer and find this pathetic. Hope this helps someone.
Jan 22, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Poor design
Your right on all counts...
is it less then a year...check for warranty..
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Jul 17, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Polti Vaporetto
Dear Terena
Had the same problem with a polti vaporetto 1500 ( vtt 1500 ) after butchering the big valve on the top I realised that the problem was that there was a blockage in the black pipe that comes from the machine to the trigger, the pipe that carries the steam in other words, so I got a piece of wire ( brake cable form a bike shop ) long enough to go at least half way down the pipe and then I pushed the wire down the hole at the trigger end and then from the other end that joins to the polti and hey presto the blockage was gone and the machine works fine again. If you use the machine again after you have cleared the blockage from the pipe you should be able to remove the valve from the top remeber that the water is now steam so it is very hot and will burn you so be carefull when opening the valve when hot I think that you will have to open it when it is warm not hot as what has happened is that scale has got in the threads of the valve and sealed it, so if you get it undone ( try pushing it down hard as you turn it Whilst it is warm only not hot ) then get some kettle descaler and put some in a bowl of hot water and put the valve threaded end in the descaler for 10 minutes to get rid of the scale and in the mean time put some descaler around the threads on the polti where the valve goes this will allow the valve to screw back on easily and you will be back to normal use again remember to keep the valve screw threads free of scale in the future I have only just reallised this so dont feel alone.
Pete
Sep 26, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
2,003 people viewed this tip
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
