Tip & How-To about Televison & Video
T-CON board in LCD TV training and troubleshooting
Http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
PDF download: http://www.mediafire.com/?zzjygannjty
SONY forum: http://www.agoraquest.com/index.php Exerted:
Sony will be announcing the availability of limited TCON replacement boards to service LCD panels beginning
with certain models going back to 2006. For many years technicians have been asking about the availability
of these components. In the relatively small percentage of units that experienced a failure of the TCON board,
replacement of the entire LCD panel was mandatory. This is not only costly from a warranty standpoint but it also
makes it near impossible to justify an out-of-warranty repair since the replacement LCD panel can easily cost 2/3
or more of the price of the entire television.
Televison & Video Logo
My Sony TV KDL-46XBR8 begun showing lines in the middle of the screen about a week ago and now is showing a transparent block at each top corner. The TV is only two years old. Do you have any solutions for this issue?
More likely to be the T-CON board.
Does it look like this in my albums?
http://s807.photobucket.com/albums/yy352/budm/SONY/Sony%20KDL-46WL140/
You will want to read or download the T-CON troubleshooting also.
T-CON: E40951307-TCON Troubleshooting 10-22-09_OPT
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
http://www.mediafire.com/?zzjygannjty PDF download
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jul 13, 2011 | Sony BRAVIA KDL-46XBR8 46 in. LCD TV
When I turn my 52"
Bad T-CON, or bad power supply can be the cause of the problem.
See example here:
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Download and read more here:
Jul 12, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
picture is in vivid colors on right hand side. been told its the module. if so what part number is it. thanks
So half the screen is bad? I am not sure the exact problem you are having.
Please download the info here on how to find out if you have screen or T-CON board problem:
LCD panel: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Jun 19, 2011 | Televison & Video
Did you ever get your Sony Bravia fixed? Mine was one month out of warranty when I started getting the lines and distortion. Paid 1500 for it new and they say the part to fix is 1600 but Best Buy haven't come out and looked at it yet. Sounds like Sony needs to recall the tvs.
Sony model number?
Vertical lines, please read here about bad T-CON/LCD panel. I owuld suspect the T-CON board or bad connections on the ribbon cable between the T-CON and the LCD panel.
SONY T-CON: E40951307-TCON Troubleshooting 10-22-09_OPT
Please see if you are seeing the same problem as shown here:
Jun 13, 2011 | Televison & Video
lg 34lh20 tv screen lower half of coming horizontal colour lines in time by time
It can be power supply, T-CON board, ribbon cables, LCD panel.
Please download and learn about the T-CON/LCD panel problem to help you narrow down the problem.
May 19, 2011 | Televison & Video
2,009 people viewed this tip
Top Televison & Video Experts
