Tip & How-To about Computers & Internet
How to recover shortcut files from a flash drive or memory card
Ever experienced plugging your flash drive or memory card and found that your files have been made shortcut and when you tried opening the file nothing happens? Here is one solution that can recover your files.
1. when you plug your flash drive and see the shortcut files, do not delete the files as it will take longer time to recover it. Take note of the drive that reads your flash drive. (see the highlighted text)
2. on the start menu, type cmd (command prompt)
3. open the command prompt window which looks like this
4. then on the c prompt type: chkdsk (name of the drive of the flash drive {e.g. g or d}) the command prompt will look like this:
5. then you will see the following words on the command prompt
6. wait until it is completed
7. then type exit, to close the command prompt window
8. check your flash drive now, the shortcut files have been recovered.
9. now, you need to clean your flash drive to remove the virus. You have to have a good antivirus to do this.
10. you can now delete the shortcut files if it not removed automatically by the antivirus you used to clean the flash drive.
these steps helped recover my files from my flash drive. Hope it will help you too.
if the steps above did not work or did not recover your shortcut files, you can try this alternative
11. on the command prompt, type: attrib -h -r -s /s /d g:\*.* your command prompt window will look like this:
12. wait until it is finished or until you see:
13. then exit the command prompt window then check the files on your flash drive, not only will it recover the shortcut files but it will also recover some deleted folders
Computers & Internet Logo
4 gb usb creating shortcuts folders
I think you are referring,that there are folders and shortcuts which are not created by you and its generating automatically?
if this so, Its an action of a virus. - Run full system scan using a up-to-date virus scanner.
Mar 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Hi i have 2gb sd card, when i opened it in my system, it is showing shortcut folder and the memory is 2mb. I stored almost 1.8 gb files. But i could'nt see anything, please help me on this issue.
SaveMyUsb.com can recover data from most damaged and faulty flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 30, 2010 | SanDisk 2GB microSD Memory Card
after removing the memory sd from the cam it can't be viewed on the computer. Files only appears as shortcut
When you plug your memory card in to your computer, do you see a new drive icon appear in your My Computer window? ...or, does a wizard pop up asking you if you want to copy files to your computer?
When you say that the files appear as shortcuts, do you mean that when you go in to the DCIM folder on your memory card where your pictures should be, you see a whole bunch of shortcuts with names similar to what your pictures file names usually are, or do you mean that the icon that you normally use to open the memory card is a shortcut?
If you right-click on one of the shortcuts, and click properties, where does the shortcut point to?
Oct 25, 2010 | Vivitar ViviCam X345 Digital Camera
usb flash drive showing shortcuts inside, help me, how can i remove shortcut virus from a "microsd memory card"?
Is this the Problem???
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
  • 100% free
  • Setup file to download 1.1 Mb
  • Installed file 2 Kb
It will recover your all data.
DOWNLOAD !!!
http://shortcutvirusremover.blogspot.com
Sep 08, 2010 | SanDisk 1GB microSD Memory Card
Memorex U3 traveldrive,USB 2.0 won't open Word '03 file in Vista,says, ''shortcut path does not exist.'' But shows it in there at 450 KB? Help. Thanks, Charles
try to copy the file on the hard drive and then open it and make sure the file u are mentioning is not a shortcut sometimes we even send a shortcut into the usb drive instead of the real file by mistake so check it
Jul 09, 2009 | Electronics - Others
2,747 people viewed this tip
David Payne
David Payne
