Tip & How-To about Office Equipment & Supplies
How to elminated sc402
Some times transfer unit current didn't receipted charge properly there is two springs charge transfer unit if one of both out of position may causes sc402
is printing blank
No transfer charging. Poor contact of engine PWB's transfer bias output terminal and printer's contact (spring). Check the installation position of the engine PWB. No developing bias output. Poor contact of engine PWB's developing bias output terminal and printer's contact (spring). Check the installation position of the engine PWB.
Poor contact of engine PWB's developing bias output terminal and developing unit's contact.
Mar 11, 2015 | Kyocera FS4020DN (A4) Workgroup Mono Laser...
Changed rear brake shoes on 88 mustang. Drum wont go on because Front shoe sitting too high. Won't stay down in proper position. Seems that all springs and hardware put together properly. What would cause this?
Not fully conversant with this model, but wonder if it's possible you have 'auto-adjusters' fitted, and perhaps you didn't wind them back before fitting the new shoes?
Jun 07, 2012 | 1988 Ford Mustang
I had the head gasket replaced in my 2002 Kia Rio. Now I lose power when I go up hill. What could be causing this?
Excessive back pressure due to a clogged catalytic converter would be the first thing i would check. In fact, that could be related to the head gasket failure you had....
Reply back if you need further assistance.
Good luck & i hope this helps FixYa!
Aug 25, 2011 | 2002 Kia Rio
e0067-0110
E067 High voltage-related error
0100 The measured current of the primary
transfer ATVC is abnormal twice in
succession.
Check on the primary transfer roller spring, Clean
the position where the primary transfer roller
contacts, Replace the primary transfer roller,
Replace the drum unit Check a value
of COPIER> DISPLAY> MISC> DRM-LIFE, and
replace the drum unit if the value is near 100
because the drum may have reached its life
expectancy.
0110 The measured voltage of the primary
succession.
Turn OFF and back ON the main power
Jun 07, 2010 | Canon iRC3100 Printer
Docucolor 242 code 042-326. What do we need to
arrwup.gifBSD On BSD 9.20 - Transfer Belt Position Monitoring arrwup.gifDescription Belt Home Position too long
arrwup.gifInitial Action NOTE:
If this fault is declared 3 times in succession, the print mode will be disabled. In order to clear this condition, reset NVM location 741-105 to 0.
  • Check the opening/closing of the Front Cover.
  • Turn the power OFF then ON.
arrwup.gifProcedure Check that the Transfer Belt is in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Center if required (see REP 9.3).
Perform ADJ 9.13 Belt Edge Learn Cycle.
The Belt Edge Learn Cycle ends abnormally. Yes No Unanswered
End
Check the reflective mark at the rear of the Transfer belt.
The reflective mark positioned correctly and reflects properly. Yes No Unanswered
Clean the reflective mark and reposition it properly, if the problem continues, replace the IBT belt ( PL 7.3).
Enter dC330 [042-200 Transfer Belt Home Sensor]. Rotate the belt manually for 1 turn.
The display changes. Yes No Unanswered
Go to OF 99-1 and troubleshoot the Transfer Belt Home Sensor ( PL 7.5).
Check the operation of the actuator of the Transfer Belt Edge Sensor Assembly.
The actuator moves smoothly. Yes No Unanswered
Replace the Transfer Belt Edge Sensor Assembly ( PL 7.4).
Select [042-016 IBT Steering Motor (CW) High Current] and [042-017 Steering Motor (CCW) High Current].
The IBT Steering Motor operate. Yes No Unanswered
Go to OF 99-9 and troubleshoot the IBT Steering Motor ( PL 7.4).
Check the installation position of the IBT Belt Module (the four legs of the IBT Belt Module are placed on the board springs of the Transfer Drawer and the fixing screws (M4: x2) of the IBT Drawer are tightened).
The IBT Belt Module is installed in the proper position. Yes No Unanswered
Adjust the installation position of the IBT Belt Module.
Set dC131 [741-105 Angle Data Initial Value (A0)] to 0.Install the IBT Belt in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Perform ADJ 9.13 Belt Edge Learn cycle.
End
Replace the Transfer Belt Home Sensor ( PL 7.5). If the problem continues, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem persists, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem is persistent, replace the IBT Belt Module ( PL 7.1).
Sep 08, 2009 | Xerox Office Equipment & Supplies
981 people viewed this tip
k24674
jasbo
jasbo
