Tip & How-To about Office Equipment & Supplies
How to retrived your machine from misfeed or stacking up in fuser unit
First introduction misfeed have alot of places in machin copiers actually some times trays is not convenient with criterion on machine that mean yo have tray a4 horizontal if yo made a3 it's make misfeed and fuser unit make misfeedes in fingers may broken and may cooler roller accumulate on it masses of burned toner make heavy load on fuser unit mechanism
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
it is showing the following signs U1, A,C
look my dear that is misfeed positions ok a; that mean first tray misfeed and tray2 c; that mean misfeed in fuser unit u1; mean misfeed in sorter
Jan 08, 2011 | Ricoh FT5832 Copier
Copier Sharp AR-M237 a Misfeed Occurred message
First try a different tray to see if it works, if it does than the paper tray you are using may have dirty feed tires or look for something obstructing it.
Mar 24, 2010 | Kyocera CopyStar CS-3060 Black and White...
adf misfeed ar-m237
Try cleaning the pick rollers with alcohol or clean cloth dampened with water.
Feb 10, 2009 | Sharp AR-M237 Copier
Misfeeds
DEAR SIR WHERE YOU REMPVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEAZ CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Sep 16, 2007 | Sharp AR-M455N Copier
741 people viewed this tip
k24674
jasbo
jasbo
