Tip & How-To about Computers & Internet
Three Tips for Windows XP Administrator Password Recovery
Unlike Windows 7 and Vista, the default administrator account on Windows XP is enabled and not password protected. And by this unique feature, you can easily reset a forgotten login password to Windows XP when you are locked out of computer. But if you added a password to this built-in administrator account before and now cannot remember its password, what will you do to reset this forgotten Windows XP default administrator password? Here's some advice on Windows XP administrator password recovery for you if your Windows XP machine is in use.
Tip 1: Take advantage of password recovery disk
Provided a password reset disk for the default administrator account is created in advance, Windows XP administrator password recovery can be completed within a few clicks.
Step 1. Go to Windows XP logon screen and enter a wrong password for the administrator account.
Step 2. Press Enter to pop up the "logon failed" dialog box, and click "use your password reset disk".
Step 3. On the Password Reset Wizard screen, click Next to change this administrator password.
Tip 2: Try Windows Password Recovery Software
If you forgot Windows administrator password without a password reset disk, don't feel impressed. Rekeysoft Windows Password Recovery can solve your problem. It allows you to create a password reset CD/DVD to reset lost Windows XP administrator password.
Step 1. Download and install Windows Password Recovery.
Step 2. Burn a bootable password reset CD/DVD.
Step 3. Boot your locked computer form the CD/DVD.
Step 4. Reset Windows XP password under Win PE.
Step 5. Log on computer via this administrator account without password.
Note: With intuitive GUI, you can defeat Windows XP administrator password within a few clicks, regardless of your level of computer knowledge. 100% recovery rate guaranteed.
Tip 3: Use a user account with administrator permission
It is well-known that users can create 2 kinds of administrator account on Window XP. One is a user account with administrator privileges while the other is the built-in administrator account. So when you forgot Windows XP default administrator password, you can log on computer with another kind of administrator account and then do as follows:
Step 1. Right-click My Computer icon to select Mange.
Step 2. On the coming up classic computer management window, expand Local Users and Groups folder, and then expand Users folder to display all user accounts on this computer.
Step 3. Right-click Administrator and select Set Password option.
Among these tips, it's highly suggested you try tip 2 that changing Windows XP password with Windows password recovery software as it is can be applied to every lost Windows password circumstances. And it is simple and fast.
Computers & Internet Logo
what is default admin password for Toshiba satillite Pro C660-171
The default admin password is blank (no password)
If you're using windows 7, the admin account is disabled by default and you have to enable it.
Follow the directions here to enable it:
http://www.howtogeek.com/howto/windows-vista/enable-the-hidden-administrator-account-on-windows-vista/
Sep 08, 2011 | Toshiba Computers & Internet
How to enable Windows 7 administrator account and reset lost Win 7 admin password There are two parts for your Windows 7: * Enable Windows 7 administrator account * Reset lost Win 7 admin password With 240 million licenses sold out in one year, Windows 7 has been proved to be a successful product of Microsoft. Compared with its previous versions like Windows XP, it has many improved features. The built-in administrator account is one of the features. In Windows XP, there is a default administrator account after installation. But the built-in administrator account is disabled by default in Windows 7. To enable Windows 7 administrator account and assign a password to it, you can achieve it in 2 methods. Part I: Enable Windows 7 administrator account Method 1: Use Command Prompt The easiest way to enable the Windows 7 built-in administrator account is to use the Command Prompt. 1. Click Start and type CMD in the search box. Right-click CMD and select Run as Administrator. 2. Click Yes when prompted to allow the Command Processor to run. And then the command prompt will appear. 3. Type net user in the command prompt window, and then hit Enter. All the Windows account user names will be listed. You'll also see the Administrator account, but now it is not enabled. 4. Type net user administrator /active:yes and hit Enter to enable Windows 7 admin account. Now the Windows 7 administrator account is created. To create the Windows 7 administrator password, you can follow the below steps: 1. Switch to log on Windows 7 with the administrator account. 2. Click Start, Control Panel, User Accounts and Family Safety and User Accounts in order. You'll enter the screen where you can make changes for your account. 3. Click Create a password for your account on the screen. 4. In the coming screen, type and confirm your Win 7 admin password. 5. Enter password hint and click Create Password. Now your Windows 7 admin password is successfully created. Method 2: Use Local Users and Groups 1. Click Start and type lusrmgr.msc in the search box, and then hit Enter. The Local Users and Groups screen will come up. 2. Double-click the Users folder. And all the Windows 7 account will be displayed for you. 3. Right-click the Administrator account and select Properties. 4. Uncheck the "Account is disabled" check-box and click OK on the administrator properties screen. Now Win 7 admin account is enabled. To set a password for the enabled Windows 7 administrator account, follow the steps as below: 1. Right-click the Administrator account and select Set Password. 2. Click Proceed to go on your operation 3. Type and confirm your new Win 7 admin password and click Ok 4. Close the Local Users and Groups screen. Now the Windows 7 administrator password is assigned to your Windows 7 admin account. Part II: Reset lost Win 7 admin password Windows 7 administrator password reset Tips: Note 1. Please remember to create a Windows 7 password reset disk after assigning Windows administrator password. It allows you to change your forgotten Win 7 admin password when you are locked out of Windows. Note 2. If you forgot to create the password reset disk, you can choose to use Windows Password Breaker to help create a Windows 7 password reset disk rather than reinstalling the system. Now follow the steps to create the disk to reset Windows 7 password. step 1. Download and install Windows Password Breaker. step 2. Run the program and burn a Windows password reset disk. Step 3. Reset Windows 7 administrator password with the disk. It is an easy and safe way for Windows 7 admin password reset.
Nov 02, 2010 | Computers & Internet
How to Recover Windows 7 Administrator Password
To avoid reinstalling your system, the easiest way to resolve the problem is to use some Windows password recovery program. The program will enable you to reset the password to "Blank"; with no -reformatting or installation. reset Administrator password for you automatically. http://www.resetwindowspassword.com/
Jun 02, 2010 | Computers & Internet
5 Ways to Reset Windows Administrator Password in 7/Vista/XP/2003/2K/NT
hi,thank you for your post,Windows Password Recovery 6.0 is quite useful,I have solved my problem now
May 07, 2010 | Computers & Internet
819 people viewed this tip
David Payne
David Payne
