Tip & How-To about Health & Beauty
Remove your eye makeup with ease!
It is never a good idea to leave on eye makeup overnight.Leaving makeup on your skin overnight can get into your eyes and can possibly be a cause of eye infection. When removing eye makeup, it is important to keep in mind that the skin around your eyes is really sensitive. Being harsh on it can produce wrinkles and fine lines. Thus, you should always be gentle when taking off your eye makeup.
Gentle eye makeup removers made of readily available oils found at home are the easiest and best way to remove eye makeup while providing moisture for your skin. You can make gentle eye makeup removers through the use of natural oils. Some oils that you may consider are olive oil, castor oil, jojoba oil and vitamin E.
  • Olive Oil- promotes a smooth radiant complexion and helps maintain the skin's elasticity. It can also be used all over your face by mixing it with honey and egg yolk.
  • Castor Oil- a natural remedy for dry skin. It is also an affordable beauty aid that help thicken and shine your brows and lashes, and helps you grow your lashes longer.
  • Jojoba Oil- wonderful for those who suffer from sensitive skin conditions.
  • Vitamin E- acts as a powerful antioxidant.
You may use one of these products alone or a mixture depending on the ratio and consistency that works best for your skin. It is also important to keep in mind that all of these products are natural and are subject for spoilage. You may have to keep your homemade remover inside the fridge to prevent it from going bad.
Health & Beauty Logo
What are the disadvantages of cosmetics?
Some of the disadvantages of cosmetics include:
* too expensive( the good brands)
* can ruin your skin with acne, pimples and oily/dry complextion
*some cheap brands can give you an allergic reaction
* different brands are used for different skin types, you may get the wrong skin type
*Cosmetics can leave you with nasty make-up lines
* clog your eyelashes together
*dry your lips out
*can get in your eyes.
these are just some but make up looks good but can ruin your natural beauty
MOST IMPORTANT RULE:
DO NOT PUT MAKE-UP ON TO COVER PIMPLES BECAUSE YOU ARE EMBRASSED, IT WILL MAKE THEM WORSE!!!
JUST LEAVE THEM, THEY WILL GET BETTER QUICKER IF YOU LEAVE THEM ALONE!
Nov 22, 2010 | Health & Beauty
Best makeup for grey eyes, very dark eye brows, olive skin and blonde/brown hair?
For fall plums and rich browns. Do a smokey charcoal eye. I too have blue gray eyes but very dark hair.
1,367 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
