Tip & How-To about Office Equipment & Supplies
Resetting the Ink Waste Absorber Error Message
Below Works with most Canon Range of printers.
By using this tool you can reset the waste tank counter and can sometimes reset the ink level monitors.I have included two procedures.
Method 1 1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Method 2 First you need this tool : http://www.ziddu.com/download/14685220/PCM_servicetool.rar.html
Then the following steps: Step 1: enter in service mode in order to use the resetter:
  • Turn off the printer without pulling the power cords.
  • Hold down Resume button and press Power button.
  • Keep holding down Power button and let Resume button go.
  • Then Press Resume button 5 times then let both buttons go.
  • The Alternate Blinking error is gone: the printer is in Service Mode state.
Step 2:
Extract the resetter and double click "servicetool.exe"
  • Click Reload Button and you will get a new USB port.
  • Load some papers in your printer and press the "Main" Button, wait until it shows "error 001" then press OK.
  • Then press "EEPROM" button and the printer will print some text, after that click OK
  • Then power off the printer (sometimes you have to press twice the power button to turn off) and turn on again.
  • That's done.
I hope this helps anyone who has a issue with the Error codes. You can usually reset it 2 times before it will actually overflow. It can also assist in re-setting error codes
RegardsGM
wat tank full mp 520
Hi Guy,
I believe that what you mean is 'Waste Ink Tank Is Full' error on Canon MP520.
To fix this problem, first you need to reset waste ink counter of the printer then you should replace the ink absorber with new one.
In order to reset waster ink counter properly, you can read complete procedure how to reset waste ink counter of the printer below:
How To Reset Waste Ink Counter Canon MP520 Multi Function Printer
May 07, 2014 | Canon MP520 All-In-One InkJet Photo...
I need to reset my Canon Pixma MP160 manually.
Follow the steps below to do Reset on your printer.
  • Turn on the printer to reset then run MPTool software
  • Click Reset Black on Ink counter to reset ink level black cartridge or click Reset Color to reset ink level on the color cartridge.
If this does not work, try the steps below
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
  • Start with printer on then run this software
  • Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Dec 13, 2010 | Canon PIXMA MP160 All-In-One Printer
canon mp 390 waste ink near full
Some user tried the procedure to reset waste ink tanf full on Canon MP 360 and ... Reset Ink Level for Canon MX300 · Reset Counter Canon iP1500 and iP1000 ...
tricks-collections.com/waste-ink-tank-full-reset-canon-mp360/
Dec 06, 2009 | Canon SmartBase MP390 All-In-One InkJet...
Message-the waste ink absorber is almost full on pixma MP130
That is usually Canon's sneaky way of telling you that is nearing time to buy new printer. Used on older machines without chips on cartriges. After "almost full" msg, usually follows "waste ink tank full" after which printer becomes unusable. Solution: Google "waste ink tank full" reset tool and run it, that should do the thing.
Oct 16, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon Pixma MP150
Besides service tool, mptool is the popularness software to reset printers canon pixma series like MP150, MP160, MP170, MP180, MP450 and MP460. Excess of software that is the program measure of small and amenity of usage. Ability of the software that is to reset level black and color cartridge at canon pixma mp series. And there also facility to write and read EEPROM in the printer. Other excess this software is detect automatically installing printers in the computer.
Reset Ink Counter.
Reset ink counter that is resetting ink level (ink metrer) cartridge at printer.
  • Reset Black – reset level black ink cartridge.
  • Reset Color – reset level colour ink cartridge.
Reset waste ink counter
  • Reset Main (main).
  • Reset Platen (additional).
go to this website download this software after that install it follow by instruction that i give to you do reset....
http://www.mediafire.com/file/yan3ytvdumt/MPTool.zip
Sep 16, 2009 | Canon PIXMA iP1600 Printer
7,023 people viewed this tip
k24674
jasbo
jasbo
