Tip & How-To about Cameras
How to Unlock SD Card
Many times people do not realize that a SD card can be write protected or locked. They will try to download pictures or make changes to the pictures and the SD card will not allow them to do it. The little lock feature on the side of the card will write protect the SD card so that changes cannot be made. You will need to unlock the SD card to be able to make the changes that you want to make or download anything from it.
To allow the SD card to be accessed is a simple as sliding a small tab on the side of the card to the unlocked position. Usually this means sliding the tab towards the back of the card and away from the front of the card. The card will have to be removed from the camera or PC to be able to do this.
Here is a picture of an SD Card and you can see the tab on the side of the card. It clearly shows you what is the locked and unlocked positions on the card.
This feature can be very useful to make sure that you do not inadvertently erase data or pictures from the card. If you have children viewing pictures on the SD Card make sure to lock it before allowing them to play around to make sure that they do not erase your pictures.
As you can see this is a very good feature to have and it will be very useful to you, but you do need to remember to unlock it before trying to make changes to the card.
Cameras Logo
kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
How do i make the card write protected go away
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 10, 2014 | Cameras
SD memory card is locked. How do I unlock it?
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Jan 20, 2013 | Sony Alpha DSLR-A290L Digital Camera
my Canon EOS camera was working fine. Now that I want to take pictures it say card write protection. How can I fix the came so I can take pictures?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If this doesn't do it, try another card.
May 16, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
how do I unlock my sd card it says (card locked) every time I try to take a picture.
Dec 31, 2010 | Vivitar VPT-360 PROFESSIONAL FLUID-ACTION...
7,326 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
