Tip & How-To about Computers & Internet
How to find your Router's IP address
The easiest way to know your Routers Internal IP address is by using a little command line tool called ipconfig. This command line is built in with Windows Operating System and is being used for various networking solutions. To use this, you need to click Start and find the run command. Click the Run command and you should see a little run dialog box after.
In the run dialog box, type in cmd and either press ENTER or click the Ok button. You should see a black window with white text and this is referred to as the command prompt.
At the command prompt type in ipconfig and press enter. That should display three major information. The IP Address, Subnet Mask and Default Gateway. The IP address in line with Default Gateway is your router's Internal IP address.
Each Router has Internal and External IP address. The internal IP address is what you use to talk to your router. Use this IP address to login to your router setup page and configure it for things like port forwarding. External IP address is what the rest of the world uses to find you on the Internet.
Hope this helps.
Computers & Internet Logo
Find IP address for my Dell Dimension E520
If you are using Windows OS , type ipconfig/all command in COMMAND prompt. i.e .,
[ Start -> Run -> cmd -> ipconfig/all ] ,to know your physical and public IP. You can also use the online IP lookup tool -> IP-Details.com to find your public IP.
Apr 14, 2013 | Dell Dimension E520 PC Desktop
What is an ip address
An IP address is also known as Internet Protocol Address.It is very important in Internet.Every Internet users are identify by their users using their IP address.IP address is Unique.You can get it from your Internet Service Provider[ISP].
IP address are two types.
There are Internal and External IP address
Internal IP means that your system IP address.
If you want to know your system ip address follow these steps:
Start--->run-->Type cmd
Then command prompt will display.
type ipconfig
then it will display your system IP address
External IP address means that your network IP address.
If you want to know your Network IP address then visit IP-details.com here it shows the details like ISP(Internet Service Provider),IP location,country,latitude,longitude etc..
Mar 15, 2013 | Computers & Internet
how do i change my ip adress on netbook
First you can find your internal ip address of your netbook by using these following steps
Goto START> RUN> Type CMD> Command prompt open here Type " ipconfig/all "
You can change your internal ip address
Again go to command prompt
  1. Type "ipconfig /release" (without the quotes, on the command line by itself).
  2. Type "ipconfig /renew" (without the quotes, on the command line by itself).
If you want to know your external ip address Just visit the site Ip-Details.com
your external ip address assign by your internet service provider. if you want to change this do the following procedure
  1. Log into the router's admin console. (Often http://192.168.1.1/)
  2. Release the IP address. (Method varies by router manufacturer)
  3. Turn off router, ethernet hubs/switches, and the cable/DSL modem.
  4. Leave off overnight.
  5. Turn everything back on.
Jul 04, 2012 | Computers & Internet
whte is my ip addres
Open a command line (e.g. run CMD to get a 'dos' prompt) and execute:
IPCONFIG
The line with IPv4 will have your IP address
Sep 20, 2011 | Linksys Wireless-G Broadband Router
UVERSE 2WIRE 802.1 LAPTOP ADAPTER
Try to acquire an address from the router by performing a ipconfig /release command, then ipconfig /renew at the command line. If that doesn't work then you may have to manually enter IP address and DNS address and Default Gateway address in the IP Properties page of your adapter. Could be your present address is using APIPA or Windoze Automatic Private IP Address of 169.254.x.x
Jun 24, 2008 | Computers & Internet
1,014 people viewed this tip
David Payne
David Payne
