Tip & How-To about Office Equipment & Supplies
My paper is revealed faintly with toner un clairly
This problem happened when i put new toner first try to make recovery to toner andpress2207 and show if it's works ok if there is till appear check that housing with green knob send toner to devolper tank or not some times backwards gears on machine fret thus devolper tank may effected if it been almost empty and laser revealed some times blurred image faint imagein ricoh 2035
resetter of samsung Ml3470 laser printer resetter
Try this...
1 Press Menu until System Setup appears on the bottom line of the
display and press OK.
2 Press the scroll buttons until Maintenance appears and press OK.
3 Press the scroll buttons until CLR Empty MSG. appears and press
OK.
4 Select On and press OK.
5 Now the Toner Low Replace Toner message does not appear but
the Replace Toner message will remain for reminding you that the
new cartridge needs to be installed for quality.
The User Manual (ver. 6.00) is available at...http://www.samsung.com/us/support/owners/product/ML-3471ND/XAA
Jun 08, 2014 | Samsung ML-3470 Series
put new toner cartridge in copier; says "adding toner' but it still says "add toner to resume copying"
press 10871087 then press 130 then press START(green button) the meter will show 9 and continue to descend till it shows GUD power off/on
Sep 23, 2011 | Kyocera Mita Office Equipment & Supplies
Why now acer.
YOU HAVE PROBLEM WITH YOUR HDD try to remove old and install new OS in new HDD!
If not write back,ok?
Oct 16, 2007 | Acer Aspire 5100-5022 Notebook
system freezes
277 people viewed this tip
jasbo
jasbo
