Tip & How-To about Compaq Presario Notebook
How to Reset Compaq Password?
"Compaq password reset to recover or unlock my forgotten Compaq Presario password is needed for me! Will the lost HP Compaq password make my data lose?" Many HP Compaq PC users ask such questions once meet password problem. Now, let's share three common methods to solve the issue!
Method 1: DIY a CD/DVD/USB Compaq password recovery disk
It is the most efficient way to reset lost password for our Windows 7, XP, Vista and Server 2008, etc. Compaq laptop or PC. The main procedure is to burn an .iso image file to your bootable CD/DVD/USB. Now, take one of top-rated Windows Password Recovery tool as example:
A. Download Ainorsoft Windows Password Recovery and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible PC;
B. Boot the burned CD/DVD or USB Flash Drive from the PC lost password;
C. Reset a new Compaq password.
Method 2: Accounts with administrative privileges
It is easy to be ignored to use administrative accounts (the built-in admin included). Take Compaq Windows 7 as example:
A. Login PC from the accessible account with administrator privileges.
B. Start - Local Users and Groups - lusrmgr.msc in the Search box - ENTER. If there is prompt for an administrator password or confirmation, type the password or give confirmation.
C. Local Users and Groups - choose Users.
D. Right click the account needed to reset password, and then select Set Password.
E. Input and confirm the new password.
Method 3: With created Compaq password reset diskette
It is the last but not the least way to help us remove locked password. If we have the diskette before lost Compaq password, problem will be easy. Now, we together learn how to create a password reset disk and how to use it. (Take Windows XP as example)
A. Start -> Control Panel -> User Accounts.
B. Select the user you need to set a disk.
C. Choose "Prevent a forgotten password" on the left of Related Tasks.
D. Prepare a blank floppy disk and then do the following operation as the Forgotten Password Wizard. When the progress indicator displays 100% complete, click "Next" and then Finish.
E. Remove the floppy disk from PC and keep it.
Reset a forgotten Compaq password with following steps:
F. Click the username when we get to the Windows logon screen and then press Enter when password box appears.
G. Click use your password reset disk. The Password Reset Wizard starts and Next.
H. Insert the password reset disk, and then Next.
I. Type a new password in the Type a new password box and in the confirm box.
In the Type a new password hint box, we can type a hint to remind us the password if we forget the new password if we want to use one.
J. Click Next, and then Finish.
With the above three ways on Compaq password reset, we need not worry about how to unlock HP Compaq password now.
Compaq Presario Notebook Logo
reset windows 7 password compaq presario
To reset Windows 7 password on compaq presario, there are several free methods:
1. With another admin account.
2. With Windows 7 password reset disk.
3. From Safe Mode.
4. With CMD.
5. Using "lusrmgr.msc"
Best solution: Reset forgotten Windows 7 password on compaq presario with Windows Password Recovery Tool 3.0.
1. Install this program on another computer and create a password recovery disk with USB
2. Insert the disk to your laptop and set your laptop to boot from it.
3. All user accounts will be loaded, then you can reset any user password.
For more: http://www.windowspasswordsrecovery.com/hack-computer-login-password.htm
Feb 03, 2012 | HEWLETT-PACKARD Compaq Presario CQ56-129NR...
i forgot my administrator password!!! i cant strat my lap! how to recover this problem
If you have a Windows password reset disk, you can easily reset forgotten Windows password with it. If not, you can follow the steps to create one. You just need an available computer which can link to the Internet.
Step 1: Download and install Windows Password Breaker with the available computer.
Step 2: Run the program and burn a Windows password reset bootable CD/DVD or USB flash drive.
Step 3: Reset your forgotten Windows password with the created disk or USB.
It is easy and safe.
Feb 13, 2011 | HP Compaq Presario C700T
i forgot password for my labtop hp compaq presario 2100 2195us
This all-in-one password recovery software will surely help you out. It is capable of resetting forgotten or lost Windows Administrator login password, and recovering lost password for multiple web browsers, mail clients, FTP clients, chat messengers etc. HP Compaq is supported. Good luck!
Jan 23, 2011 | Compaq Computers & Internet
Compaq nx6310 PC Notebook: i need to unlock my hp nx6310 cmos password...
Compare to many password recovery solutions. Following solution is the best and the easiest one i found.
1.Download Windows Password Recovery 6.0 from Password Recovery Official site : recover lost password
2.Decompress the Windows Password Recovery 6.0 and note that there is an .ISO image file . Burn the image file onto an blank CD with the burner freely supported by Windows Password Recovery 6.0 3.Insert the newly created CD into the locked computer and re-boot it from the CD drive. 4.After launched the CD, a window pop up with all your account names(if you have several accounts); select one of the accounts that you have forgotten its password to reset it. Just one press, you have removed the password.
May 18, 2010 | HP Compaq nx6310 Notebook
how do i unlock my labtop?
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
Jun 11, 2008 | Compaq Presario Notebook
3,287 people viewed this tip
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
