Tip & How-To about Apple iPhone Smartphone
How To Save Battery On Your iPhone or iPod Touch
Is your iPhone or iPod Touch's battery level always depleting quickly? Do you not have enough juice to get you through the day? Here are some quick tips to conserve your battery life and help you get through the day while you are Facebooking, sending texts, and calling.
First, lets make sure you can monitor your batter level. This is how you will turn on the percentage of battery display.
1. Go to your home-screen.
2. Open up the Settings App.
3. Tap General then Usage
4. Where it says battery percentage, make sure the switch is in the on position.
Now that you can monitor your battery life, here are a few things you should continually do to save battery.
Don't keep multiple apps running if you don't have to. iPhones and iPod Touches have multitasking to run multiple apps at once, but this can use a lot of battery. To delete tasks, double tap the home button and then hold down an icon at the bottom of the screen. Once the apps begin to wiggle, tap the X by the app to stop the task (note: this won't delete the app, it will only stop it from running).
Another battery saving setting is not fetching email quite as often, I mean, do you really need to check your email every 15 minutes or hour? Fetching data uses a lot of battery, to disable or not as frequently fetch for data, go to the Settings app again. Go to Mail, Contacts, Calendars then Fetch New Data and set it to Manually so to check email, go to the email app and click the refresh button.
Your iPhone has an adjustable brightness, and a higher brightness wastes more battery, to change the brightness: go to your Settings app. Go to Brightness and turn your brightness down. You don't necessarily need to turn it all the way down(especially when you are in bright lighting conditions, kind of ironic that you need higher brightnesses in brighter environments), but if you are in a pitch black room, then there is no reason to have the brightness above the minimum level.
Another good habit is turning off bluetooth and wifi when you are not using them, to do this, go to your Settings app again. Go to Wi-Fi and turn of wifi. To turn of bluetooth, go to General then Bluetooth and turn it off.
If you don't necessarily use an app a lot or at all, turn off Push Notifications. To do this scroll all the way down on your Settings app, and choose that particular app. This will only be useful on an app that gets information from the internet. In the particular app that you chose, usually there will be a Push Notifications option, and you can disable this, this will help your battery because your iPhone constantly tries to search for data with these on. Also, when installing apps, you can disable this then.
Another good way to save battery (iPhone only) is to switch from the 3g(fast internet)radio to Edge(slower internet) radio. On the iPhone, you have twice as much battery with Edge radio. To change between the two, go to your Settings app once again. Go to General then Network and where it says Enable 3g switch it to off. You can/should do this when you aren't heavily surfing the internet, checking Facebook, or downloading apps. Don't use this with apps that require heavy internet usage.
One final tip to conserve battery is changing the amount of time until the iPhone/iPod Touch goes into sleep mode. If you forget to put it in sleep mode, it will stay on and waste battery in your pocket, etc. To change the amount of time to save battery, go to your Settings app again. Go to General then Auto-Lock and change it to something short such as 1 or 2 minutes.
These tips will significantly prolong your battery, use them to your advantage.
Apple iPhone Smartphone Logo
how do i restart my disabled ipod
Hold SELECT + MENU for a few seconds, that will reboot your Ipod, providing there's enough juice in the battery, the hard disc is not dead, etc ....
May 29, 2016 | Apple iPod touch
I have had my iphone less than a week- i did not expect it to have problems so soon. .... i have iphone 2g my battery ran out now it wont recharge or turn back on? .... but it doesn't turn on, it only vibrates when I try to charge it. .... and showing apple but not going on.i keep start my iphone till bettery dead. ...
If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
Jun 28, 2011 | BoxWave Corporation Apple iPhone 2G...
When I charged my iPhone 4 with the Mophie Cover & Battery Backup installed, all contacts disappears. I lost all assigned special ringtones.
The Mophie has no influence and can't influence the actual content on your iPhone, there is another reason, please indicate anything strange/out of the usual you did previously.
Mar 21, 2011 | Mophie JPT2BLK Juice Pack Battery for iPod...
1,377 people viewed this tip
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
