Tip & How-To about Ricoh Aficio 1035 Copier
How to get ride of horizonal and vetical lines revealed in paper
This problem means that laser unit cable is defective try to cutting it and scratching until solid pins revealed again and pack it in his position properly and before do that unplug power cord and machine some times appear again rolling right or left changeable resistor first one yo have two in your machine to left try more times.andwe must realize that this lines revealed too much in paper
Ricoh Aficio 1035 Copier Logo
Ricoh mpc 2050 sc 222
222 Laser synchronizing detection error: start position [Y]
The laser synchronizing detection signal for the start position of the LDB [K], [Y], [M], [C] is not output for two seconds after LDB unit turns on while the polygon motor is rotating normally. Disconnected cable from the laser synchronizing detection unit or defective connection. Defective laser synchronizing detector. Defective LDB. Defective BICU.
May 23, 2015 | Ricoh Aficio Mpc2050 Color Digital...
hı sc 322 laser unut problem ld unut end laser connector poor cable error
Hello sir; Sometime this problem can be reset, just let's try, ; Press " clear mode ", "107", "stop/clear" key until screen show out sp mode then turn power off and back on again.
Oct 11, 2009 | Ricoh Aficio 1035 Copier
sc 322
Hello sir; Try to reset if not work you need to replace laser unit, the reset procedure as follow; press "clear mode " then 107 then press " clear/ stop " until screen change ,then touch "copier sp " ,then turn power off and back on .
Aug 26, 2009 | Ricoh Aficio 1035 Copier
2,486 people viewed this tip
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
