Tip & How-To about Computers & Internet
Blue Screen of Death - How Do I Fix It
Those who are using Windows operating system are aware about the Blue Screen of Death (BSOD) and may be they have faced it in their PCs. This is a common error which usually occurred when something wrong with PC in hardware and software. Sometime it occurred when some major problem has been created in PC but it also come when a minor corruption occurred in it. So, the most important thing to recover the desktop screen is to detect the problem.
Blue Screen of Death has not proper technical guideline to solve but it has various way to resolve - depends upon condition or error. Sometime it automatically resolves by restarting the PC but sometime it take great effort and time to resolve. In short there is no simple answer of "how the blue screen of death can be resolved?"
To get the desktop screen and resolve the BSOD, user has to recognize the error. This error detection can only be done manually because both parts - hardware and software, are checked one by one. At the blue screen the error is displayed but this display shows the error in computer codes which are not easy to understand by the user. But these codes help to diagnose the error. So, once you get the BSOD error write down it on a paper.
Unfortunately, if you couldn't get success to resolve the BSOD by rebooting the machine, then you have to do some effort for resolving the problem. It is not easy to concise the instruction of all resolving method that's why there are some hints to resolve but if you cannot resolve the blue screen error through the following guideline, then write the error code on search engine and get method for resolving through Internet.
The first method of diagnosis the problem is to check the windows at safe mode. If you couldn't get success to reach the desktop screen in safe mode that's means there must be a hardware problem. One of your computer physical devices has been corrupted or destroyed. To resolve the screen in this condition check your devices one by one in other PC.
If you get desktop screen in safe mode, so you're PC has software or driver problem. Once you reach at the desktop screen, scan your PC through anti-virus immediately. The anti-virus will detect the software if there will be anything wrong. If anti-virus detects any software which is virus infected, uninstall and delete the software immediately from your computer, then re-install the windows because your PC have get the virus.
Sometime both of the above method has been failed and computer reached at the desktop screen in safe mode and anti-virus also doesn't find any infected file. This is the condition of driver failure. You have to re-install the driver to resolve the blue screen of death.
Computers & Internet Logo
Windows Vista BSOD
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jul 20, 2010 | Microsoft Windows Vista Home Premium with...
win 7 blue screen of death on shutdown? happens on one in five shutdowns the others take several minutes (10) to complete the process.
Then press any key.
Then type "y"
Jul 16, 2010 | Dell Computers & Internet
I have a WNDR3300 and a desktop running XP. When I try to connect wirelessly, I get the blue screen of death. Two other PCs (both running Vista) are working fine
Its may be of low virutal disk space increase it at right click on mycomputer --> click on properties --> select advanced --> under performance click on settings the top most one --> then click on advanced again --> under virtual memory click on change --> select the operating system drive and increase the value and click on set and click on ok --> ok if this dosent solve the problem then the issue might be with your operating system got corrupted better you reinstall your operating system
Mar 25, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Blue screen caused by SPCMDCON.SYS STOP:0x000000050 (0xfd3094c2,0x000000001, 0xfbfe7167, 0x000000000) M/c rebooted and blue screened again after about 5 mins this has gone on for an hour before I gave up
Then press any key.
Then type "y"
Feb 16, 2010 | Microsoft Windows XP Home Edition
Blue screen of death presario v2000
Then press any key.
Then type "y"
Feb 11, 2010 | HP Compaq Presario V2000 Notebook
324 people viewed this tip
David Payne
David Payne
