Tip & How-To about Cameras
How to easily download Pictures from Digital Camera
Many people are having trouble downloading the digital pictures that they take on their digital cameras to their computer. This can be a very simple procedure by doing things just a bit differently then most of the digital camera instructions tell you to do it.
I seems that every digital camera manufacturer wants you to download your pictures by hooking the digital camera to the computer through some type of a wire. While this will work for many cases, the digital camera then also causes your computer to download or have you install other drivers that can be unstable and load your computer up with more stuff, that just causes it to run slower. There is a very simple way to avoid all of the problems and very easily download your pictures.
The first thing that you need to do is to find out what type of media card your camera saves the digital images on. Some cameras use a media card or stick that is brand specific, but many digital cameras are now using a simple SD Card to store the pictures on. No matter what form your camera uses there are card readers that can read the card without it being in the digital camera. By removing this card and installing it directly into a card reader in your computer you can easily access the pictures without all of the other problems.
Many newer computers are installing a number of different card readers directly into the computer. If you have the correct reader installed in your computer already then just insert the card into the reader and then if the card does not show up, just look for it in your start menu under "computer". It will be visible under the "removable storage" devices in the menu.
If you do not have a card reader installed in your computer, you are still okay. You can purchase a card reader for your specific card easily. They are readily available and do not cost very much. I use an SD Card reader that looks like this.
I also use a separate USB Adapter so that I can plug many USB devices into my computer even though I do not have enough USB Ports in my computer to handle all of them at one time. Do not worry, the computer will still recognize them all and you can still access them all easily.
Once you have the card reader plugged into your computer, then just insert the card into the USB card reader and then go to your computers start menu. Find the "computer" and click on it. Then find the card reader under "removable storage devices" and click on it. Then follow through clicking on the prompts till you start to see you pictures being loaded. You can then just delete, copy or move the pictures just as you would any other file on your computer.
One last thing to remember. If you are having trouble accessing the digital pictures or removing them from the card, make sure that the card is not "locked". If you look closely at this picture, you can see the word "lock" and an arrow. If the little tab on the side of the card gets pushed towards the "lock" position you will not be able to do anything with the digital pictures on the card. Move the tab to the forward position "unlocked" and you will be able to do what you want to do.
This will give you an easier way to download your digital pictures without all of the problems that the camera drivers will give you. You will eliminate many potential problem spots by doing it this way and it will work just as well for you!
How to Unlock SD Card
Digital Camera Manuals, Drivers, Downloads, and Support
Cameras Logo
I am having trouble downloading pictures from camera to vivitar experience can you help?
Try NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Vivitar Experience, or any other photo cataloging program.
May 21, 2010 | Vivitar ViviCam 8025 Digital Camera
sony dsc
please visit (sony-mea.com) & down lode the require soft ware
Apr 25, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Downloading pictures to my computer
I don't use software or anything like that. Here is what I do:
1- Plug camera into USB cord (with it being plugged into your computer)
2- Turn on your camera, a blue screen will appear with options, select "PC"
3- Open your "My Computer" folder, you should now see a new drive, I have 2 hard drives so my camera is usually under "H://"
4- Select your picture(s) and drag and drop them into a folder or wherever it is you wish to store your pics. It will not remove them from your camera or memory card, it will simply copy them.
5- Power off your camera and remove the USB cord.
Simple as that! :) Again, that is just how I do it! I use Ulead PhotoImpact to edit my pics and such. Hope that helps!
Oct 08, 2008 | Polaroid T730 Digital Camera
7,497 people viewed this tip
Top Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
