Tip & How-To about Computers & Internet
Why is there no sound coming from my speakers?
If you hear no sound coming from your speakers, there could be several reasons:
1) Check to see if the speakers are powered on.
2) Check to see if the cable is plugged into the speakers and the green jack in the back of the computer.
3) Check to see if the speakers are muted in Windows. Do this by clicking on the speaker icon in the system tray. It has a place to check to mute the speakers.
4) Check to see if the sound devices and drivers are loaded. To do this go to the control panel and click on "sound." Then click on the sound tab. Choose one of the Windows events that has a sound associated with it and preview the sound by clicking on the arrow to the right of the listing. If the arrow is dark and when you click on it the sound seems to be playing, then the drivers and sound card should be functional. If the arrow is grayed out, then your sound drivers are not installed. In either case, try reinstalling the sound drivers.
5) If you've tried all this to no avail, try with another set of speakers.
6) One thing that may work is to do a system restore back to the time the speakers were working.
7) If nothing works, I would suspect that you have a bad sound card. Unfortunately, these days sound is integrated into the motherboard, but you could install an add-on sound card.
Computers & Internet Logo
While using Skype with my Toshiba laptop and webcam the sound will all of a sudden cut out. I have to end call and then click video call again to get the other party can hear me and after a few minutes, the sound will cut out again.
1. this could be several reason why the sound cut out when using skype
2. check the hard drive capacity
3. you may need more RAM ( random access memory). If you are at minimum this may not be enough to complete the VOIP ( voice over IP)
4. this could be the connection with the skype recipient.
5.check your skype settings
6.check the sound card in your laptop ( drivers etc)
7. check the speakers of the laptop the may be malfunctioning or the earphones if used.
Jun 13, 2011 | Computers & Internet
i can not hear any volume through my computer speakers
heres a checklist
1) check the power cable of the speakers
2) check whether you have connected the speakers in right hole in your computer
3) check whether your have installed the proper drivers for your sound card
Nov 15, 2008 | HP Computers & Internet
I have lost sound on my xp home edition windows for no apparent reason. Any chance of help. Thanks
If you have lost sound on the PC there could be several reasons:
1. if you use speakers the speakers could have either become unplugged, the souns could be turned down or muted.
2. The sound card could have gone bad.
3. You could have downloaded a Microsoft update that corrupted your sound.
Do the following:
1. Check you speaker cables to make sure they are plugged in correclty if you use speakers
2. Check the sound icon by your system clock in the toolbar at the bottom of the screen. If it has a red X then this is where the issue is, if not then click it and make sure it is 'Off' mute.
3. Click start right click 'My computer' and go to device manager on theproperties tab. Make sure the driver for your speakers does not show a yellow or red indicator.
If you still have an issue then go to: startr, accessories, system tools, system restore and restore the pc to a checkpoint before the date you lost your speakers/sound.
Oct 20, 2008 | Computers & Internet
Whats this?
Hi, might be several reasons: 1) to loud, the amp might be auto protecting; 2) one of your 4 speakers has a developed an intermittent problem, either open or coil grounding to magnet; 3) the pigtail (wire from terminal to coil) might be occasionally touching the metal body of the speaker (just carefully bend/move the pigtail out of the way); 4)impedance mismatch (speaker ohms too low for the amp) or too many speakers connected (check/replace or lessen); or 5) it is possible that the amp is not getting enough power from the battery/electrical system or a loose ground somewhere (although a bit unlikely). Hope this be of some help. Please let us know how things turn up. Cheers.
Apr 15, 2007 | Sony XM-SD46X Car Audio Amplifier
Laptop Shutdown Issues
1) For sounds, you can check the sound properties and see if the balance is set right for the left and the right speaker. Alternately, move the balance to the left and see if you hear anything 2) There can be lots of reasons why the laptop would shutdown automatically. Does it shutdown or would just turn off without a proper shutdown. It can be due to some device - especially the processor getting heated or some device is not getting enough power for the system to remain up. Please revert back with further observations.
Apr 07, 2007 | Acer TravelMate 4654LMi PC Notebook
832 people viewed this tip
David Payne
David Payne
