Tip & How-To about Computers & Internet
How to Bypass or Remove a BIOS Password using Software:
!BIOS is a freeware utility which is designed to be a whole BIOS and security suite. It has the ability to decrypt the passwords used in some of the most common BIOS makes such as Award, Phoenix, American Megatrends, IMB etc..
It also has the ability to brute force the password (known as "blasters"). However, this method is dangerous and can result in some unexpected and unwanted results. Note: Because of this applications password cracking abilities, some antivirus software may report it as a virus/trojan. This is a false positive.
To start using !BIOS, reboot your computer and take note of the BIOS type and version you are running. For example, If your motherboard uses Award BIOS you should look for the text "Award Medallion BIOS 6.0′ or something similar.
Download !BIOS from here and save it to your desktop. Then, open a DOS command windows by going to Start > Run and type: cmd
Once you see a black screen in front of you, type: cd desktop
You should now see something like: C:\Documents and Settings\YourUserName\Desktop>
Now type the name of the file you just downloaded, if you haven't changed the name just type in: bios320.exe
Use the down arrow and choose "Crackers" and then press the right arrow. Using the up and down arrows, select the BIOS that the motherboard is using and press Enter.
You should now see a menu asking what you want to crack, in most cases its the Supervisor or System Passwords you want to crack, so press the 1 key on your keyboard. It will then show you another menu asking how you want it to be cracked. Option 1 is pretty good so try that first by pressing the 1 key on your keyboard. You should now have your BIOS password.
Reboot the computer, enter the BIOS and try it out.
Computers & Internet Logo
no possibility to reset the bios password - do you see any chance without the expensive customer service
Hi
Try this one to reset the password.
BIOS passwords can be reset in two ways,
1. using software 2. using hardware.
I would first try resetting using software, here are two software's to reset orretrieve BIOS passwords.
!BIOS- is a PC BIOS toolkit offering password removal/decrypt and BIOS settingsmodification/backup/restore.
CmosPwd- Cmos password recovery tools
Please let us know if it works.
Jun 08, 2011 | Fujitsu LifeBook E780 Notebook
I have inherited an old Kapok Model 2100P notebook and cannot get past the Boot Password I thought if I replaced the cmos battery it my do the trick but I do not have a manual for the unit and so I am unsure what CMOS battery is compatible
replacing the cmos battery on notebooks can be tricky try this instead
To start using !BIOS, reboot your computer and take note of the BIOS type and version you are running. For example, If your motherboard uses Award BIOS you should look for the text "Award Medallion BIOS 6.0? or something similar.
How to Bypass or Remove a BIOS Password using the manufacturer ba
May 12, 2011 | Computers & Internet
i have laptop compaq presario v3000 i have set bios password and now i forgot my password so is there any way to break the password, i had disassembled and assembled full laptop than also it doesn`t reset pls give me some way..........
May 12, 2011 | HP Compaq Presario V3000T Notebook
MY COMPAQ EVO N400c HAS A POWER ON PASSWORD THAT I HAVE FORGOTTEN I NEED TO PASS IT TO MY SON BUT HE CANT USE IT COS OF THAT I HAVE REMOVED THE RTC BATTERY AND THE MAIN POWER PACK FOR A LONG TIME AFTER I PUT IT IT STILLS REQUEST FOR THE POWER ON PASSWORD WHAT DO I DO
Many manufacturers leave a backdoor password built in, especially on older Laptops. Try entering 'Compaq' including the capitalisation. If this doesn't work then you could try using !BIOS.
!BIOS is a freeware utility which is designed to be a whole BIOS and security suite. It has the ability to decrypt the passwords used in some of the most common BIOS.
May 04, 2011 | Compaq Evo Notebook N400c
can't open because there's a bios password
BIOS passwords can be removed three ways essentially, although each one has its difficulties.
1. Take the computer apart and remove the CMOS battery (the small battery that maintains the time for the computer's clock. This solution is the fastest and easiest if you feel comfortable taking the computer apart, locating the CMOS battery and removing it:
2. Call the manufacturer and try to attain a back-door BIOS password from them.
3. Software solution (from Technibble.com)
Now type the name of the file you just downloaded, if you haven't changed the name just type in:bios320.exe
Dec 21, 2010 | Computers & Internet
6,354 people viewed this tip
David Payne
David Payne
