Tip & How-To about Office Equipment & Supplies
HP M1522 Freezes, does not start, blank control panel
If you have an HP M1522 and you are getting any of the following:
  • no display on control panel
  • Unit freezes on start with "Initializing" or just arrows in display
  • Printer will not power on at all or shuts off intermittently
  • Unit stops functioning, appears frozen and control panel does not respond
There is a good chance that your formatter is bad but there is hope for you.
Check the back of your product for the sticker with the serial number on it. Also on that sticker is the date of manufacture. If your machine was manufactured before January 1, 2010, then HP has a service advisory that addresses this issue. A service advisory is an admission by HP that the product does not meet expected standards and as such they offer a free repair of the machine, regardless of the warranty status of the product. HP will replace the formatter on your machine and it will not cost you a dime. You simply need to contact HP at 1-800 HPINVENT. This service advisory is valid until December 31, 2011.
scanner error 14
the problem with scanner assembly
Mar 20, 2013 | HP LaserJet M1120 MFP All-In-One Printer
Server won't start
I would first try reseating (removing and putting back) the SCSI card. If it is not able to reseat (built into the motherboard) you can always try to get into the BIOS diagnostic and run a system diag on the machine.
regards,
Mike
Oct 23, 2012 | HP Compaq ProLiant ML350 G5 Server
HP M1522 Printer Switches its self off shortly after printing, what could be wrong?
Hello, pretty common problem with this printer, follow the link for more details.
M1522mfp Freeze and Hang CLICKHERE
Feb 22, 2011 | HP LaserJet M1522nf Multifunction Printer...
Display is stuck on "initializing..."
1. disconnect it from any other devices.
2. turn the printer off and unplug it.
3. plug it back in and try again.
Dec 16, 2010 | HP PSC 1610 All-In-One InkJet Printer
2,643 people viewed this tip
k24674
jasbo
jasbo
