Tip & How-To about Office Equipment & Supplies
HP M2727 freezing, no control panel display, shuts off.
If you have an HP M2727 and you are getting any of the following:
  • no display on control panel
  • Unit freezes on start with "Initializing" or just arrows in display
  • Printer will not power on at all or shuts off intermittently
  • Unit stops functioning, appears frozen and control panel does not respond
There is a good chance that your formatter is bad but there is hope for you.
Check the back of your product for the sticker with the serial number on it. Also on that sticker is the date of manufacture. If your machine was manufactured before January 1, 2010, then HP has a service advisory that addresses this issue. A service advisory is an admission by HP that the product does not meet expected standards and as such they offer a free repair of the machine, regardless of the warranty status of the product. HP will replace the formatter on your machine and it will not cost you a dime. You simply need to contact HP at 1-800 HPINVENT. This service advisory is valid until December 31, 2011.
We have a M2727 Laserjet Printer/Fax . We can print, and we can receive fax, but our problem is sending a FAX.. Keeps giving us an error code of 49. Please advise Thank-You, Marla
I found this on the HP website:
HP LaserJet M2727 Multifunction Printer Series - 49 Error Message Is Displayed While Faxing ISSUE: The printer control panel will be displaying 49 service error while sending faxes. The receiving fax will be lost, and the printer will display the same error even after reboot. SOLUTION: Performing a factory reset and a firmware upgrade is the only solution for this issue. Step 1: Performing a factory reset Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name and phone number. CAUTION: This procedure clears fax numbers and names that are associated with one-touch keys and speed-dial codes, and deletes any pages that are stored in the memory. The procedure then automatically restarts the product. Perform the following steps to restore the factory-set defaults: 1. On the product control panel, press Setup . 2. Use the arrow buttons to select Service , and then press OK . 3. Use the arrow buttons to select Restore defaults , and then press OK . The product automatically restarts. Step 2: Firmware upgrade After coming to ready, upgrade the printer firmware from the HP website. The issue can be fixed with any of the firmware upgrade available now. Firmware version 20080505 and higher versions have the fix. You can download firmware version 20080612 from the HP LaserJet M2727 Firmware Update 20080612 webpage. Click here to go to the HP LaserJet M2727 Firmware Update 20080612 webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3377075&swItem=ma-55531-3&prodNameId=3377076&swEnvOID=228&swLang=8&taskId=135&mode=4&idx=3) . The preceding steps will resolve the issue.
Mar 07, 2011 | HP Office Equipment & Supplies
Display is stuck on "initializing..."
1. disconnect it from any other devices.
2. turn the printer off and unplug it.
3. plug it back in and try again.
Dec 16, 2010 | HP PSC 1610 All-In-One InkJet Printer
m2727 will not initialize.
You have to be a little bit more specific next time, we have 2 possible scenarios:
A) The printer freezes at the HP LOGO
B) Blank display / No display
Both are usualy caused by a problem in the formatter (Mainboard) . There is nothing you can do to recover it. If the printer is still under warranty you will need to call HP (1 800 334 51 44) or take the printer to an athorized warranty depot in your area. This link will help.
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
I can tell for sure that the warranty for this specific model M2727 will be extended 1 extra year (means you have 2 years coverage) if the printer has one of the issues listed above I Hope this can help You can contact me directly on : eliteprintersolutions@hp.com
Jun 01, 2010 | HP Laserjet M2727nf Multifunction Printer
1,148 people viewed this tip
jasbo
jasbo
