Tip & How-To about Office Equipment & Supplies
HP M1522 Scanner 5 or Scanner 8 Error
UPDATE: HP is no longer honoring this repair.
If you have an HP M1522h and you are getting this error, there may be hope for you. Check the back of your product for the sticker with the serial number on it. Also on that sticker is the date of manufacture. If your machine was manufactured before January 1, 2010, then HP has a service advisory that addresses this issue. A service advisory is an admission by HP that the product does not meet expected standards and as such they offer a free repair of the machine, regardless of the warranty status of the product. HP will replace both the scanner assembly and the formatter on your machine and it will not cost you a dime. You simply need to contact HP at 1-800 HPINVENT. This service advisory is valid until December 31, 2011.
Printer screen had update message. After I pushed the OK button, it gave error code Oxba10AACC
Hi Wendy!
Sorry to tell you but OX___... messages means "failed printhead or ink system"
You should try to change the printhead because an error occured and the printhead it's no longer working
Hope you found it useful, for every futher question i'm here
Source: HP Troubleshooting
Dec 04, 2015 | HP Office Equipment & Supplies
HP-2727mfp scanner error problem
HPM2727mfp - Scanner Error 5 - Scanner Error 8
These errors indicate a problem with the flatbed scanner assembly. The flatbed is no longer able to initialize or find home position. The scanner may move back and forth continually and the light flicker at a high rate of speed. The flatbed scanner will need to be serviced/changed. The part required is CB532-67905
M2727SCANNER
Please contact your local Hewlett Packard Repair Center.
HPPARTNERLOCATOR
Jan 02, 2011 | HP Laserjet M2727nf Multifunction Printer
I have HP 3390 Laserjet MFP. The USB port no longer works
What is the exact error message you receive?You don't mention what OS you're using, but have you seen this article? Also make sure you have a good power supply to the printer. (refer here.) Possibly update your printer drivers.
Also check through these steps. Check here. And make sure you can ping the printer. ( see here).
Here's a list of resources for troubleshooting xp printer issues. There are similar available for vista here.
Finally, HP has a lot of resources available online for your printer, including parts. See here.
If you can't seem to resolve the issue with that info, write back with more details and we'll be happy to help you get it sorted out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 24, 2009 | HP LaserJet 3030 All-In-One Printer
error 79 ...shuts off and the screen says error 79
Hi angelahender:
Here is your problem.
79 Error
PowerOff>PowerOn
The product has experienced an
internal firmware error.
Disconnect the power cable from the
product, wait at least 30 seconds, then
reconnect the power cable and wait for
the product to initialize.
If the error persists, upgrade the firmware.
Firmware update via flash executable
The configuration page lists the firmware version of the product. On
flash-memory-based products, you can update the firmware code by
downloading the latest flash executable for the product and running
the program according to the readme instructions that come with it. If
the firmware should become corrupted or fail (usually because of an
interruption when attempting to update the firmware), the product will
no longer function. In this case, a firmware recovery DIMM is
available from HP.
Hope this helps
Jul 16, 2009 | HP LaserJet 3330 All-In-One Printer
441 people viewed this tip
k24674
jasbo
jasbo
