Tip & How-To about Video Game Consoles & Games
Fix your PS3 Yellow light of Death.
You can fix it yourself. The CPU was to hot and the solder has come off. Bad part is the solder is under the CPU and must be heated up. It is lead free so it needs more heat then lead and you need to add flux. I would start by getting the board out. Remove the thermal paste off the CPU. Add flux with a flux pen. You want to get the flux under the CPU so you might want to tip it on its side. After you have a good amount of flux under the CPU you want to start to heat the parts around the CPU. I would use a heat gun with temp. settings. You first want to heat around the CPU to keep solder on the other parts from cracking. You dont want to over heat the parts. After you preheat the board you want to heat the CPU. It needs to be around 400 or 500 degs f. a good 15 or 30 sec. keep moving the heat gun. After heating the CPU you want to start the cool down. Same as warming up the board but you want the board to cool down slow. After all this you want to add New thermal paste to the CPU. This helps transfer from the CPU. This is a must because your PS3 is overheating as it is. After you do all this some people say it only works for 2 to 6 weeks. Its all on how you fix the board and how good of a job you did. I would back up your hard drive. Then hope for the best!! good luck and i hope this helps you out.
Video Game Consoles & Games Logo
How do i fix error code 0023 on xbox 360.
This is a confirmed error code on either the GPU or CPU(most of the time the GPU). Your console got way to hot and cooled off, got way too hot and cooled off etc etc a multitude of times and created hair line fractures in the .06mm solder balls under either the CPU or GPU. Microsoft really screwed the pooch on first(white/phat) generation consoles by three things. Bad heat sink design for both the CPU and GPU, Bad tin/lead solder combination, and bad airflow. To resolve this you would either have to send the motherboard into microsoft to have both the CPU and the GPU undergo a process which is called reflow, AFTER both were lifted from the motherboard and replaced with a higher quality solder AND THEN upgrade the heatsinks to something of higher quality. I even go the extra mile on these things and dremil out a large hole on the top of the case to duplicate a fan install that you see present in the black models.
Sep 11, 2014 | Microsoft Xbox 360 Console
when the system is turned on the power light goes green for a second or two and then beeps and goes red.
You can fix it yourself. The CPU was to hot and the solder has come off. Bad part is the solder is under the CPU and must be heated up. It is lead free so it needs more heat then lead and you need to add flux. I would start by getting the board out. Remove the thermal paste off the CPU. Add flux with a flux pen. You want to get the flux under the CPU so you might want to tip it on its side. After you have a good amount of flux under the CPU you want to start to heat the parts around the CPU. I would use a heat gun with temp. settings. You first want to heat around the CPU to keep solder on the other parts from cracking. You dont want to over heat the parts. After you preheat the board you want to heat the CPU. It needs to be around 400 or 500 degs f. a good 15 or 30 sec. keep moving the heat gun. After heating the CPU you want to start the cool down. Same as warming up the board but you want the board to cool down slow. After all this you want to add New thermal paste to the CPU. This helps transfer from the CPU. This is a must because your PS3 is overheating as it is. After you do all this some people say it only works for 2 to 6 weeks. Its all on how you find the board and how good of a job you did. I would back up your hard drive. Then hope for the best!! good luck and i hope this helps you out.
Apr 14, 2011 | Sony Playstation 3 (PS3) Console
my playstation 3 will turn on and then flashes a yellow then red light then turns itself off.
Feb 20, 2011 | Sony Playstation 3 (PS3) Console
-it is a power problem. -i turn on my ps3 system using the main power button on the back of the console and the red light comes on in front. -i then touch the standby button in front and the red light turns to green with a beep sound and a blue light comes on next to the green. -about three seconds later there are three short beep sounds and the blue light changes to a blinking yellow. -the green light goes back to red and the yellow light goes off -i touch the standby button again and hear a beep sound but the light stays red. -i touch the standby button again and the whole process repeats. -this only happens when the console has been turned off for long periods of about 24 hours
Dec 26, 2010 | Sony Playstation 3 (PS3) Console
my ps3 will turn off after being on for a couple of secounds and a yellow light starts to blink
Dec 25, 2010 | Sony Playstation 3 (PS3) Console
1,129 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
