Tip & How-To about Kitchen Ranges
Power off for 5 Minutes
We had this display failure twice within the last 2 years on our 6 year old rbd305pds14 range. The display went blank, but all other button functions (light, beeps etc) remained operational.
Each time I turned off the main breaker power for about 5 minutes.
While power is off, I also (lightly) pressed and held each button on the panel for about 2 seconds - This was to further eliminate residual power due to capacitance/inductance effects that might be retained in sub-components in the circuit. (This might not be necessary, but my electronics maintenance training had us do this when the circuit is not well known - and it gives you something to do during the 5 minutes!)
Both times this has worked. So far I have not needed to access the control panel and re-seat the ribbon cable.
Note, Following the manual's advice of turning off the breaker for 30-60 seconds did NOT work, which tells me there likely is some C/I effect in the circuit, (possibly due to a subtle ground loop??, but that is for an electrical engineer to determine.)
Sincerely hope this helps you.
Kitchen Ranges Logo
GE Profile range - Digital display went blank when the surface burner was turned on
Hi
Mercedes NEC device can learn an extra key to ALL MB MOTOROLLA AND HAVANA AMAZONAS PALERMO... EIS with black or chrome key Version57
Device can repair any CORRUPTED key data VIA INFRA RED
Device can repair the old 204 steering lock or program a new steering even if the old ESL in not exist
Device works by infra red Much and much functions will be valid to all our customers
Price 7000 Euro you can visit our website to watch the you tube video
(Limited quantity only)
http://youtu.be/0Ce4z8JY-go
•Mercedes W204 - ELV
•Mercedes C W204
•Mercedes CL W216
•Mercedes A W168
•Mercedes G W463
•Mercedes GL W254
•Mercedes GLK X 204 - ELV
•Mercedes GLK X 204
•Mercedes ML W164
•Mercedes W 207 - ELV
•Mercedes W 212 - ELV
•Mercedes W207
•Mercedes W212
•Mercedes G W463 (MOPF)
•Mercedes W221
•Mercedes SL R230
•Mercedes SLK R171
•Mercedes Sprinter
•Mercedes Vaneo W414
•Mercedes Viano W639
•Mercedes R W251
•Mercedes Vito W639
Dec 28, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
How do I change the company name that's displayed on the top of the page of a fax??? It's a Canon Faxphone B740.
On the right hand key pad
1). Press Function
2). Press 01 (data registration
3). Press set twice
Display the tel number, change if that is wrong
4). Press set twice again
Enter the company name (unit name)
Use the numeric keys-max 24 characters
if you have otehr problem, please to to the following link and download the users manual.
http://www.usa.canon.com/cpr/pdf/Manuals/B740CanonUserManual3-13.pdf
May 22, 2009 | Canon FAXPHONE B740 Plain Paper Bubblejet
2,875 people viewed this tip
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
