Tip & How-To about Computers & Internet
How to speed up the booting in XP
Please follow the below steps
Goto Start>>Run
Type
msconfig
press Ok
then click Startup tab
and uncheck all items except antivirus program
then click Apply
Ok
then restart the computer
Thanks
Satchi
Computers & Internet Logo
my acer note book stratup very slow and drive not read program. what can i do this problem
Just perform the following steps:
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the last month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Click on Next and System Restore will start and windows will take a reboot.
Now Goto Strart and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'Sys config utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
goto 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
now restart windows.
To quickly restart windows press CNTRL+ALt+DEL
inside task manager you will find all the open applications .
right click on each applicaion and click on end process tree then ok
Close all your apps like this and you will find your windows a lot faster and now you can reboot or turn off your windows as usual from start button.
After reboot your problem should be resolved.
Apr 06, 2011 | Acer Aspire 5742Z-4200 Notebook
computer is very slow and every time i open wepsite it get stack
turn on the computer and keep on pressing the F8 key> select safe mode> login to desktop> go to run and type "temp" (without quotes) then hit enter and delete all the files> go to run and type "%temp%" (without quotes) then hit enter and delete all the files> > go to run and type "msconfig" (without quotes) then hit enter then goto the startup tab and uncheck all the unnecessary items hit ok and do not restart the computer> go to run and type "inetcpl.cpl" (without quotes) then hit enter then goto the advanced tab and click on reset to reset the internet explorer.
Then restart the computer it should work fine now.
Sep 06, 2010 | Computers & Internet
hi,my neighbour has lent me his D500 latitude,it is really slow opening pages and everything up.when i browse the web,ie becomes unresponsive,it freezes,only the cursor will move,but it wont click on anything.is there an app i can use to clean the system up,or can i disable running tasks,i am not the administator,just scared when it crashes,cuz i have to turn it off,by the standy switch
Please follow the steps below to make it faster a bit....
Click Start-> Run, type msconfig and click Ok. The System Configuration Utility will start. Now click on Startup tab. You will see a list of programs which starts automatically when Windows starts.
In that list, uncheck the program items, which you generally don't use. It will make your computer a little faster.
The above procedure can also be modified a little, that is uncheck all items under Startup tab, restart your computer.
Now check one item at a time, restart computer and test the speed of your computer. This way, you will find the programs, which are making the computer show. Remember to use a pen and paper to take a note about which items you are selecting or unselecting.
Please try one more thing:
Open Start-> Settings-> Control Panel-> System. Click on Advanced tab. Under Performance, click on Settings, click on Adjust for best performance, click Apply and Ok.
Then do this Click->Start->Programes->Accessories->System Tools->Disk Clean Up and select the C:Drive and clean it
Thanks
Aug 21, 2010 | Dell Latitude D500 Notebook
computer is very slow how can i speed it up?
If you are using Windows XP, use the following steps to disable some startup programs:
Click Start-> Run
Type msconfig and press Enter
Click on the Startup tab
Click Disable All
Click Services tab
Click on the checkbox Hide all Microsoft services
Click Disable All
Click Apply and Close
Restart the computer.
You will get a notification about using the system configuration utility.
Click the checkbox for Do not show this again
Click Ok
If the system appears to run faster, the next step will be to re-enable a few items under startup tab. You can keep most of the items disabled except your antivirus software.
Mar 08, 2010 | Dell Latitude C600 Notebook
"Webcam is in use by another application."
in ue by another app is usually a driver conflict or a virus. if you have a 3n1 printer or a scanner unplug it and reboot the pc see if you get the same message. if not update the scanner or printer drivers. if the messgae return even after the reboot try a clean boot next.
To Boot Clean in Windows Vista Accessing the System Configuration Utility
1. Click Start and select Control Panel
2. Click System and Mantience
3. Click Administrative Tools
4. Double Click System Configuration
Configure Selective Startup options
1. On the General tab, choose Selective Startup
2. Uncheck Load Startup Items
3. Select the Services tab
4. Check Hide all Microsoft services
5. Click Disable all
6. Click on OK
7. Click Restart.
After performing the necessary steps, restore your system by doing the following:
4. Double click System Configuration
5. On the General tab, choose Normal Startup
6. Click Ok
7. Click Yes, when asked to restart your computer
To Boot Clean in Windows XP
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. On the General tab, choose Normal Startup
3. Click OK
4. Click YES, when asked to restart your computer
if the camera starts to work after doing this your looking at a virus have your pc cleaned by a pro.
Jul 20, 2009 | Logitech QuickCam Pro 9000 Web Cam
154 people viewed this tip
David Payne
David Payne
