Tip & How-To about Cuisinart DCC-1200 Coffee Maker
How to repair a DCC-1200 Cuisinart Coffee Maker
Problem #1 - DCC-1200 makes steam - not coffee. Reason: the check valve is plugged - water will not flow.
Solution #1 - Remove the check valve located inside one of the 2 silicon tubing hoses inside the coffee maker...and clean the valve. You must remove the bottom of the coffee maker (problem #3). Note: the check valve is not plugged due to hard water minerals. It plugs up from coffee grounds and coffee residue. Thus...use the charcoal filter, and clean with 50% white vinegar on a regular basis.
Problem #2 - Removing the check valve located inside the tubing. You must cut it out and thereby destroy the tubing. Replacement is required.
Solution #2 - purchase one foot of 3/8" SILICON tubing over the Internet from Rebel Brewer at www.rebelbrewer.com. Silicon is required to handle the high temperature.
Problem #3 - removing the bottom plate. It is secured with four "custom" torex screws that cannot be removed with a normal torex tool. (not designed to be easily removed).
Solution #3 - I used a 1/4" drill bit and drilled off the heads of the screws. The bottom is easily removed. I was able to snap it back into place. You can use some silicon caulk at the 4 corners for a more secure fitting.
Good Luck - not too difficult
Camanokid
Cuisinart DCC-1200 Coffee Maker Logo
When brewing, it steams and spits the water out
this is what happened to me, I didn't have the filter basket all the way down so the pot lid didn't open the valve that lets coffee flow so the coffee and grounds ran into the water resevior and plugged the filter, so I did the worst thing possible and took the filter out so the grounds got into the check valve that keeps the hot water going in the right direction. that makes it spit and sputter and brew slow.
after trying to flush it out forever I tore the metal plate on the bottom off and unhooked the rubber hoses (don't do this unless you have a needle nose pliers, you'll never get them back on) one should go to the brew head and the other is the water inlet, this has the check valve. you can tell which is which by blowing through them and seeing which one goes to the brew head. if you can blow through the other one the check valve is stuck open, I blew air into it with an air compresor and this forced the check valve shut and now it works fine. I know this is the same symptons as calcium deposits but I had cleaned it twice.
try flushing it with water first but sometimes it takes extreme measures
Jan 11, 2009 | Cuisinart DCC-1200 Coffee Maker
cuisinart automatic grind and brew
Clean it out with vinegar and water - 2 ozs distilled white vinegar, 2ozs water
Dec 08, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 BW Model leaks by morning if I put water in the night before to have coffee made by program. More water on the counter almost as in the pot. Any solutions? Bought 4/5/07
Order 1 foot of 5236K73 "High-Temperature Silicone Rubber Tubing" from McMaster-Carr. Put the old check valve in the new tubing in the same location and direction as originally installed.
Sep 22, 2008 | Cuisinart DCC-1200 Coffee Maker
slow water drip
First of all it depends on the hardness of the water. Vinegar doesn't really work in the heavy lime belt area of the midwest. It is better if you use lime away. It is an ecolab product that is great at lime removal. Use one cup per pot. Then rinse two pots worth if this is the kind of machine that uses the same water that is put in during each brew cycle. Some brewers have a reservoir. Bunnomatic is an example of that kind of brewer. If you use lime away in that kind of brewer you need to run about thirty pots to remove all the lime scale remover from the brewer. Slow brewing can also be caused by over softened water. I drove from Indy to Iowa after installing a brewer and then a day later the store put in a softener and over softened the water causing the coffee filter to clog up with sodium. Also check the sprayer disc or head where the water comes out. Over time coffee "paste" will build up around the outlet and if you don't wipe it clean or "smear" the coffee grounds around the outlet that will slow down the brewing cycle. I have thirty years as a brewer technician and it is usually one of the things I have covered, providing that the heat element isn't defective.
Jul 24, 2008 | Cuisinart DCC-1200 Coffee Maker
how to use Cuisinart DCC-1200 Coffee Maker to make a pot of coffee
Just bought a DCC-1200 from Goodwill for 4.95. Looks brand new. Would heat up and sputter but nothing comming through to the pot. Removed botton with T-10 torx driver. Remove hose with check valve in it. TYou can squeeze the hose about an inch down and feel it to determine which hose its in. Pushed the valve out with a screw driver over a towl so if the little ball fell out I wouldnt loose it. There was a small wad of yelllow paper clogging the valve. Removed it. Reassembled and it works great.
Jul 19, 2008 | Cuisinart DCC-1200 Coffee Maker
3,554 people viewed this tip
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
