Tip & How-To about Office Equipment & Supplies
How to get ride of sc322 in aficio 1035
That is question from complicated dispute first this problem refer to synchro1 is not detected first try to do adjustment through 2109 and 400 Dpi and 600DPI and press laser ***** beam reset and close machine and opened after 30 seconds . if this method is not work try to cut of laser cable small part and scratch to appear solid terminal and plug in ld unit correctly it's works.another way ; try to move changeable resistor in laser to left slowly small turn one more time until it's works . some times mirrors of laser unit stink with toner thus due to prevent laser beam from passed through mirrors.
solve the plroblem in di 620
The 13xx - printer engine malfunctions
13F0 -400 dpi SOS sensor detection failure.
13F1 -600 dpi SOS detection failure.
13F2-universal tray adjustment failure maximum.
13F3-universal tray adjustment failure minimum
13F4-optical system out of adjustment
Dec 15, 2013 | Minolta DiALTA Di520 Laser Printer
i have a functional problem within machine aficio DSm645 SC322
look my friend this dispute belong to laser unit sychro1 not detected laser beam ***** didn't reach to drum in same time make laser adjustment 2109 an 400 dpi and 600 dpi an close machine and opened
Apr 15, 2011 | Gestetner DSm645 Digital Imaging System
How do I change the dpi of this camera?
The digital cameras capture images with number of pixels that that image sensor allows. They usually dont have DPI adjustment. However you can adjust capture resolution from 5 Mega Pixel to 1.1 Mega Pixel. Please refer to Page 24 and 25 on the following Owners Manual for this camera.
Feb 24, 2011 | Kodak EasyShare C315 Digital Camera
how i can solve the ricoh 350 error sc-322
hii dear 322 means synchro1 not detected signal that go to sp mode yellow cancel and put 107 and hold on red cancel 3 seconds yo will see copy sp in asquar then put 2109and# and 2108and# and close machine and open if it's not work out try to clean mirrors in laser unit ok
Jan 25, 2011 | Ricoh Aficio 1035 Copier
error code sc322
that mean synchro1 not detected try to clean ld unit with carfuly and open laser unit and clean mirrors and clean sensor of synchronization it's works ok
Jan 12, 2011 | Gestetner Office Equipment & Supplies
277 people viewed this tip
k24674
jasbo
jasbo
