Tip & How-To about Computers & Internet
What is the Windows XP Administrator Password?
Windows XP, the most popular versions of Windows, was widely installed by PC users. Do you remember after you installing your first copy of Windows XP, how long did it require you to realize that you didn't know the administrator password? I vaguely remembered that it was about a week before I needed to make some changes in the file system. It suddenly came to me to be logged on as an administrator, but I do not know the password of the administrator!
Luckily, Windows XP (both Home and Professional versions) have a "hidden" administrator account which is autogenerate when install. This account usually doesn't show up on the logon screen and most people are totally unaware of its existence. Usually it is ok because we didn't need to user this account very often, only when we don't know the administrator password, need access to the Windows XP recovery console or boot into Windows XP safe mode, the default Windows XP administrator password would come in handy.
What is the Default Administrator Password in Windows XP?
Knowing the default password of Windows XP administrator account would be very useful.
  1. Try to leave the password blank. Simply press Enter without typing anything.
The default Windows XP Administrator password is defined to blank during the initial Windows XP installation process.
  1. Enter the password for your account. It often depend on how Windows XP has been installed on your computer and what part of XP is asking for an admin password, the main user account will also be configured with administrator privilege.
I Forgot my Windows XP Administrator Password!
Windows XP User Accounts applet in the Control Panel functions is to create a password reset disk wizard. Using this wizard, a floppy disk or USB flash drive can be used to create a specific password reset disk for specific user account on a specific Windows XP computer. The password reset disk can only be used with the computer it was created on and it can also be reused to reset the account's password multiple times. However, you need to know the password of the account you want to create the reset disk for, and you must create the reset disk before you forget the administrator password
Here is how to reset XP administrator password with the XP password reset disk:
  1. Insert the XP password reset disk to the computer
  2. Click the Use your password reset disk item on the XP logon screen to start the Password Reset Wizard. Click the Next button
  3. Follow the instructions to create a new password.
  4. Logon with the new password.
I Didn't Create a Password Reset Disk!
OK, if you forgot Windows XP administrator password and don't have a password rest disk, you won't be able to create a password reset disk anymore. Instead, there are several things you can try to get access to your windows. SmartKey Windows Password Recovery is your ticket. This password recovery tool not only works on Windows XP, but also on all releases of Windows NT/2000/Vista/ 7 and Windows Server 2003/2008. It works by booting from a CD/DVD or USB flash drive and reset the forgotten Windows XP administrator password.
NOTE: If you change the administrator password on a Windows XP or Windows Vista system with the Encrypted File System (EFS), all of the encrypted files will become inaccessible. The password for the Administrator account is used to create the EFS encryption key. Changing the Administrator account back to using the original password should restore access to the encrypted files, but I have never tried it.
If you only need to blank the Windows XP Administrator password, here are the basic steps:
  1. Download and install SmartKey Windows Password Recovery software.
  2. Burn the software to CD/DVD or USB flash drive.
  3. Insert newly created CD/DVD and reboot your computer from the CD/DVD or USB flash drive
  4. Reset the forgotten Windows XP password, remove the CD/DVD or USB flash drive and then reboot the computer
Having the capability to reset forgotten XP administrator passwords and regain access to a locked computer can be a great time saver, but should only be tried by an IT professional. you may probably make things worse rather than better if you use sophisticated system or manipulation tools
Article Source:http://recoverlostpassword.com/article/windows-xp-administrator-password.html
Computers & Internet Logo
what does lack of basic services mean?
means lack of compatibility here is why..Criticism of upgrade licenses pertaining to Windows Vista Starter through Home Premium was expressed by Ars Technica's Ken Fisher, who noted that the new requirement of having a prior operating system already installed was going to cause irritation for users who reinstall Windows on a regular basis.[154] It has been revealed that an Upgrade copy of Windows Vista can be installed clean without first installing a previous version of Windows. On the first install, Windows will refuse to activate. The user must then reinstall that same copy of Vista. Vista will then activate on the reinstall, thus allowing a user to install an Upgrade of Windows Vista without owning a previous operating system.[155] As with Windows XP, separate rules still apply to OEM versions of Vista installed on new PCs: Microsoft asserts that these versions are not legally transferable (although whether this conflicts with the right of first sale has yet to be clearly decided legally).[156]
Aug 13, 2014 | Microsoft Vista Home Basic with Service...
Windows xp is not starting
Windows XP is a fairly stable and secure operating system, but errors and other problems will occur from time to time. Unfortunately, some of these errors can damage or corrupt important system files and can lead to Windows XP not booting up correctly. You can repair your Windows XP installation using a process known as a "repair install," overwriting the damaged system files with new versions from your Windows XP installation disc. The repair install process takes approximately one hour, though a large portion of this time will not require any input from you.
1,Start your computer and place the Windows XP installation disc in the drive. If the computer is crashing upon attempting to boot, allow it to restart; otherwise, reboot the computer manually.
2.Press a key to boot from the Windows XP CD if prompted to do so when the computer attempts to boot again. If you are not prompted to boot from the CD, restart the computer again and press the indicated key on the initial BIOS screen to access the "Boot Order" or "Boot Sequence" menu. Select the CD or DVD drive containing the Windows XP installation CD, then press a key when prompted to boot from the disc.
3.Press the "Enter" key on the initial Windows XP welcome screen and press "Enter" again to begin setting up Windows XP. Do not press the key indicated to launch the "Recovery Console," as the Windows XP recovery console is not used to repair corrupted XP installations.
4.Accept the user agreement and wait while the setup program scans your hard drive.
5.Press the "R" key when the Windows XP setup program lists the installed version of XP that it detected to begin the repair installation. If you have more than one version of Windows XP installed, make sure that the proper version is listed before pressing "R."
6.Wait while the Windows XP setup program copies files to your hard drive and begins the installation process. The installation will take 45 minutes or longer, depending on the speed of your computer, during which time all of the Windows XP system files will be overwritten.
7.Confirm your user information as well as the date and time settings on your computer, and enter your Windows XP product key when prompted. Allow the operating system to connect to the Microsoft authentication servers to activate itself.
8.Reinstall any hardware drivers and XP Service Packs that you had previously installed, as your copy of Windows XP will have reverted to the basic installation you had when it was first installed.
I hope you find it very helpful.
Aug 25, 2011 | Gateway Computers & Internet
how to downgrade from windows 7 to xp on emachine laptop
If it is a new emachine, then it proberly will not let you. There is a problem with drivers. certain pieces of the hardware might no have any drivers that are supported by XP.. The best thing you can do is check the emachine website to see if any drivers XP. If so then follow this basic guide to format and re-install XP on your PC.
http://simontodd.com/2010/02/how-to-format-a-pc-and-reinstall-windows/
Thanks
Mar 01, 2010 | E-Machines eMachines Desktop PC
Can i install Windows Media Player 11 without checking my Windows Geniune verification?
Your friend will have to settle for an older version of Media Player, or download a copy using an internet connection and a his valid copy of Windows XP. The software you downloaded is single-user type, which Microsoft authorized for the computer you downloaded it with; and won't install onto another machine.
Jan 23, 2008 | Ahead Software Nero 6 Ultra Edition...
replacing windows XP
Dear ashwagosha If you replace or upgrade your os the nothing to worry to remove privious version do one thing:-right click on your my computer icon - properties- click on advance tab- go on startup and recovery-setting-select default operating system-edit-delete the old operating path file and save it. bye
Sep 26, 2007 | Microsoft Windows XP Professional With...
373 people viewed this tip
David Payne
David Payne
