Tip & How-To about Office Equipment & Supplies
How to Tie a Tie
The knot that will be taught is called a Pratt knot, aka the Shelby Knot. It is a simple, easy to do knot that looks good with almost any shirt and tie combination.
Step 1) Start with the tie inside out, and the wide end about a foot further down than the narrow end.
Step 2) Cross the wide end under the narrow end.
Step 3) Make a knot by bringing the wide end up and through the intersection of both ends.
See the picture below, it will make more sense.
Step 4) Experiment a little to tighten and raise the knot up to your collar.
Step 5) Once the knot is raised, cross the wide end back over the narrow end and bring it up through the collar, as shown.
Step 6) Now, take the wide end you just pulled through and bring it down through the loop, on top of the narrow end.
Step 7) Now, tighten and adjust accordingly, and you're done!
How easy is it to use a Tie Fast Knot Tying Tool?
Hi - I have one of these and just some practice is all it takes. I bought a spool of cheap line at the local store to practice with.
Not hard to learn and makes great nail knots and hook snells too.
Regards - Fred
Mar 27, 2015 | Orvis Tie-Fast Knot-Tying Tool
how do I make a knotless knot
I assume your using wire cable. Termination ends are available and a special set of pliers are required.
Sep 28, 2014 | Fishing
Do you have to tie a necktie or you can just put it on?
You have to tie a necktie. but I heard that there are some ties you can buy that you can just put over your neck. however you should know it does not look the same as a nice tied tie
Jan 10, 2013 | Clothing Accessories
How do I tie a tautline knot to secure my tent to the ground.
Take a look at this link for easy instructions about how to tie a tautline knot on your tent guyline.
Sep 10, 2012 | Camping, Backpacking & Hiking
1,029 people viewed this tip
k24674
jasbo
jasbo
