Tip & How-To about Computers & Internet
Resetting Windows XP Password with Four Proven Methods
When you need to reset Windows XP password, what will be the possible reasons? In my opinion, there are mainly two kinds of reasons. For one reason, you may have a good habit of resetting or changing your Windows XP password regularly to help keep your PC secure, as everyone knows. For another reason, you are locked out of the computer, like forgetting Windows password or buying a password protected notebook, etc. But no matter what the reason is, it's better for one to master some solutions on how to reset Windows XP password, if he still sticks on a Windows XP machine. Here shows you some simple methods on how to reset Windows XP password under different circumstance.
When you can logon Windows XP with an administrator account, password reset can be very simple and there are many solutions. The following just show you 2 examples of them.
Method One: Reset Windows XP Password Using Control Panel
Refer to resetting Windows XP password, most users will try to do it by using Control Panel as follows:
Step 1. Click Start > Control Panel > User Accounts.
Step 2. Select the user for which you want to change the password and select Change my password.
Method Two: Reset Windows XP Password Using Command Prompt
By this method, you will go to the classic user management to reset your password.
Step 1. Click Start > Run, type "control userpasswords2" and hit Enter.
Step 2. The classic user accounts management window will open, select any user and select reset password.
When you cannot access your computer due to a lost Windows password or others, or when you cannot logon Windows XP with your admin account, it requires a little technical skill to reset the password.
Method Three: Reset Windows XP Password Using Built-in Admin Account
Unlike its successors like Windows Vista and 7, Windows XP has a built-in user account named Administrator and by default it is not password protected. If you never set password for the account, you can log on computer with this admin account.
Step 1. Turn on or restart your computer.
Step 2. Press Ctrl+Alt+Delete twice when you enter its welcome screen.
Step 3. When "Log on to Windows dialog" box appears, type "Administrator" in the User name box and then click Ok to enter your computer.
After logging on, you can reset the password of the accounts on this computer by Control Panel or Command Prompt.
Method Four: Reset Windows XP Password Using Third Party Software
In addition to the methods above, you can also take advantage of Rekeysoft Windows Password Recovery, which can help you by creating a password reset disk.
Step 1. Download and install Windows Password Recovery.
Step 2. Use the program to create a password reset disk.
Step 3. Boot the computer from the password reset disk.
Step 4. Reset Windows XP password under Windows PE.
Of course you also can reset any windows password this efficient Windows Password Recovery tool, which including Windows 7/Vista admin password and Server 2000/2003(R2)/2008(R2) domain password with easy.
Computers & Internet Logo
Why do companies more like Windows XP instead of other systems?
I think peopel are used to Windows XP's peration mode and interface's functions. Or maybe is Windows XP's good compatibility. In my opnion, security is also the reason. With it I think the possibility of meeting password lost for Windows XP is low.
Dec 31, 2012 | Acer Aspire 1360 Notebook
forgot vista password to enter wiindows
It doesn't matter without a reset disk, you can use Windows Password Reset to create a new reset disk to reset windows vista password.
Here are how it use.
Step1:Download and install Windows Password Reset .
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in your newly created CD and remove your Windows Password.
Reset vista password by yourself, just so easy.
May 23, 2012 | Microsoft Windows Vista Home Premium with...
i forgot my password how do i log on
This is only possible is you are using Windows XP. If your operating system is windows Xp, follow the steps below:
  1. Turn on your computer and allow it get to the stage where is will ask for user/log pasword
  2. Press Ctrl + Alt + Del your keyboard.
  3. A user name and password prompt will pop up.
  4. On the user name type in "administrator
  5. On the password, type in "administrator"
  6. and you windows will open, go to control panel from there to change the password.
That's all. In other words, the user name and password is administrator.
But in the case of windows Vista, you will have to re-run windows operating system, because vista security is very tight and its difficult to break into its password.
Take care.
Aug 12, 2010 | Acer Computers & Internet
Windows XP Pro. driver for the acer LCD Monitor X193W
To my knowledge, it is compatible and certainly would work with XP. Since this monitor has both DVI and VGA inputs make is compatible for most video cards or even a built-in video of the PC. If for some reason the Acer X193W would not work with your Windows XP PC, possible reasons are:
  • Screen Resolution and/or Screen refresh Rate of the PC's Display Properties too high, try lowering them down;
  • hardware fault either on the monitor or video card;
  • incorrect/missing drivers of the video card;
  • it is being hooked as a secondary monitor and the dual/twin view is not activated.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Acer X193W LCD Monitor
186 people viewed this tip
David Payne
David Payne
