Tip & How-To about Cell Phones
How to Connect a Cell Phone to Computer
Cell phone has become an essential part of both domestic and professional life. But due to its small size, it is very hard to use its features for long time. However various technologies have been introduced for connecting the mobile phone with computer for getting its services in a simplest environment. By connecting cell phone with computer, you can get access to use various services of cell phone at your computer's screen.
The most notable benefits of connecting cell phone to computer are:
- It allows you to write long text in your cell phone through your computer's keyboard.
- It allows you to transfer play lists from PC to Cell phone or vice versa.
- It allows you to transfer pictures and video.
- It allows you to use your cell phone as a gateway for Internet access
- It allows you to use your cell phone's camera as web cam.
Ways of Connecting Mobile Phone to PC
Modern technology has been introducing various ways for connecting the cell phone to computer. Some of the most common technologies are:
Connectivity through Infrared:
Infrared technology offers several important advantages as a form of wireless communication. It allows your cell phone to connect with your computer but it has some drawback as well. It is found in most of the cell phone, but for connecting with your computer, you have to buy a separate device because infrared connects with other infrared device by joining both devices. If they separate for a while the connection would be broken. Moreover, its connecting speed is too slow as compare to other technologies and due to its slow speed you cannot connect your cell phone's camera as PC's web cam.
Connectivity through Bluetooth:
The most common technology for connecting cell phone with other device is Bluetooth. As compare to infrared, Bluetooth has more advantages for connecting the cell phone to your computer i.e. It is faster than infrared, it detect other Bluetooth automatically instead of joining the devices, you can easily transfer files through it, etc. but it has drawback of buying a separate device for connectivity because most of computers do not has built-in Bluetooth.
Connectivity through USB:
The cheapest but easily accessible way of connectivity is USB connectivity. It is found in both devices - cell phone and computer. All new computers have USB port and all latest mobiles have USB cable for connectivity purpose. You can easily connect your cell phone with your computer through this cable and software - software CD usually comes with cell phone and also available in market.
Cell Phones Logo
WD 500G HDD suddenly un-readable; changed name to local disk, says I need to format in order to use it. I have tons of important stuff on there.
Could you confirm if the problem with the drive not being recognized is a problem with the USB cable? I have a 250GB passport and it worked fine with my XP. Once I decided to reformat it to NTFS and tried to do so by plugging into my new windows7 laptop the problems started.
Aug 21, 2011 | Western Digital My Passport Essential...
ignition key will not turn. Tried 2 differant keys but neither will turn. Steering wheel is not jammed. Parked on flat ground. Please help
If this is not the locking mechanism in the column itself it is due to a tumbler failing to disengage correctly. When you insert the key it should move some very small pins into channels allowing the cylinder to unlock. On occasion one or more of these pins may have become locked or stuck or even fallen out completely causing this problem. You have two options and both require you to open the steering column. Replace the whole ignition switch module which should come with new keys or to open the old ignition switch module and remove all of the pins essentially making it operate with any key that will fit in the hole, I do not recommend this except in emergencies and then only until you can get a proper switch installed. You most likely will need a special Torx type driver with a center hole cut in it to remove the outer column covering. This is usually a T-20, T-25 or T-28 size. You will need to get the proper size. A regular Torx will almost grip but there is usually a small little tip in the center that will stop it from grabbing enough to remove the screws. This is a security feature to make it more difficult to steal the vehicle.
Jan 09, 2011 | 2000 Jeep Grand Cherokee
Message text is really large
press the lower volume key.the font size will change
May 03, 2010 | Samsung Star GT-S5233 Cell Phone
my lg kc550 camera feature doesn't work
hi mel, truth is, it shouldnt be anything to do with card size - mine worked before i put my 4gb in so should be nothing to do with this.
have you tried to do a master reset on your phone?
if all else fails, you are covered under the manufacturers guarantee (but if it is a network phone... say virgin, the cover will be with them as they will have their adapted software on it)
you should get a fixed phone, or a reconditioned one, or a brand new one. I would prefer the last tho :)
experiance: customer service and sales advisor for Domestic & General Insurance
Jan 01, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
224 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
