Tip & How-To about TDK 8mm MP 120 Minute Premium Camcorder Tape P6-120 8mm Tape
Always look for Video Splicing tape on google
Never!!! Never use Scotch tape on your audio or videotape, eventually a chemical reaction will cause the glue to melt down and leak to adjacent parts of the tape and damage it beyond repair. Splicing tape is specially formulated for magnetic Mylar tape, Guaranteed not to melt or bleed.Splicing Blocka device used for positioning and holding down a section of magnetic tape while splicing and joining splices with splicing tape
Electronics - Others Logo
Samsung DVD-V3650 Combo Player ejects most videotapes without playing them
You can only compensate for minor scratches. As for the vcr side the rollers could be dirty or the brake worn out. The tensioner may be too sensitive as well. Basically the mechanism probably needs servicing.
Sep 06, 2016 | Samsung DVD-V3650 DVD Player/VCR
Go 910 flatcable connectors broken
Put it back in all the way and press the upper part to "lock" it in. I guess the plastic clips used to secure it are broken. Try with some hot glue, instant glue or high quality scotch tape to keep the cable in place and lock pressed down ...
Apr 07, 2014 | Tomtom GO GPS
When I make a photocopy from the input feed (not the glass) I get a grey/black line down the page. How can I fix this?
Open the ADF....at the side of the large glass you will see a thin strip of glass maybe about 1/4 ~1/2 inch wide...there is probably some corrector fluid or glue or scotch tape on the **** of glass causing the problem.
Aug 31, 2010 | Samsung Office Equipment & Supplies
remove ashtray to repair crack around lighter housing
it has a clamp at the top or at the side that you can pinch in and remove the tray but if you use Super glue jell and scotch tape and tape everything you don't want glued then you can fill it in with super glue jell costs a buck fro two tubes at dollar store. once the glue drys remove the tape. and your done.
Apr 20, 2010 | 2001 Chevrolet Impala
both Catalytic converters glowing red , plz adv how to get them fix????
Hot catalytic converters indicate too much fuel in the exhaust. This can be caused by poor ignition/misfiring, a problem with fuel/air ratio, ignition timing, cam to crank timing(timing belt/chain).
Catalytic converters have the capability to break down excess hydrocarbons by process of chemical reaction. The more fuel, the more heat. The problem is that they will eventually melt and plug up. So I suggest you repair soon.
Oct 29, 2009 | 1993 Lexus Ls 400
1,114 people viewed this tip
Top TDK Electronics - Others Experts
 Grubhead
Grubhead
Sandy Moore
Sandy Moore
Jim Goldsmith
Jim Goldsmith
Are you a TDK Electronics - Other Expert? Answer questions, earn points and help others
