Tip & How-To about Cell Phones
How To Enter Unlock Code Into BlackBerry Mobile Phones Step By Step Instruction Guides
Model: 6xxx 7xxx: Example; 6230, 7100, and 7290 etc.:
Before you start, you MUST take out the Sim Card & turn OFF ALL wireless radios
1. Press the Menu key
2. Select Options / Settings
3. Select Sim Card
4. Enter MEPD (not case sensitive), Note: When typing in MEPD, the letters will not appear on the screen
5. Then enter MEP Hold Alt Key and type number 2. NOTE: You must use the "alt" key to enable numbers, example: enter MEP hold "ALT key" and enter 2. Note: When typing in MEP2, the letters/number will not appear on the screen, this step open up the "Enter Network MEP" box. If you do not see "Enter Network MEP" box, you didn't type in MEP2 properly.
Model: 7100, 8100, 8110, 8120 & 8220:
2. Scroll to Turn Wireless Off and press the trackball (Will show Turn Wireless ON).
3. Scroll to Options and press the trackball.
4. Scroll to Advanced Options and press the trackball.
5. Scroll to SIM Card and press the trackball.
6. Type MEPD (not case sensitive). Notice: Keep in mind for mepd is meoop on these model. Because oo = p. Note: When typing in MEPD, the letters will not appear on the screen. This step opens up the personalization on the device.
7. Type MEP, then hold ALT key and type number 2. Note: When typing in MEP2 the letters/number will not appear on the screen, this step open up the "Enter Network MEP" box.
8. Enter Unlock Code
9. Press the Enter Key. (Make sure you press the Enter Key within 5 second or you have to enter the unlock code again).
Model: 8700, 8700c, 8700g, 8700r
2. Scroll to and select Manage Connections. Select Turn All Connections Off.
3. Press the red end key or the Escape key to go back to the Home screen.
4. Scroll to and select the Setting icon.
5. Scroll to Options
6. Scroll to and select Advanced Options.
7. Scroll to and select SIM Card.
8. Type MEPD Note: When typing in MEPD the letters will not appear on the screen. This step opens up the personalization on the device.
9. Type MEP then hold 'ALT" key and type number 2. Note: When typing in MEP ATL 2 the letters/number will not appear on the screen, this step open up the "Enter Network MEP" box.
10. Enter the unlock code.
11. Press the Joydial to confirm ("Code Accepted should display)
12. Press and hold the red End key to turn the handheld off and then back on.
13. Once the device has powered on, follow steps 1 & 2 and restore connections.
Model: Curve 8300, 8310, 8320, 8520, 8800, 8820, 8900, Bold 9000,Pearl 3G 9105, 9300 Curve 3G, 9630 Tour, 9650 Bold, 9700 Bold, 9800 Torch.
Before you start, you MUST have a Sim Card (could be Active or Inactive) & turn OFF ALL wireless radios
4. Scroll to and select the Options icon.
5. Scroll to and select Advanced Options.
6. Scroll to and select SIM Card.
7. Type MEPD Note: When typing in MEPD the letters will not appear on the screen. This step opens up the personalization on the device.
8. Type MEP then hold 'ALT" key and type number 2. Note: When typing in MEP ATL 2 the letters/number will not appear on the screen, this step open up the "Enter Network MEP" box.
9. Enter the unlock code.
10. Press the trackball ("Code Accepted should display)
11. Press and hold the red End key to turn the handset off and then back on.
12. Once the device has powered on, follow steps 1 & 2 and restore connections.
Method 1: Model: 9500, 9530 Storm, 9550 Storm 2, Telus, Bell Canada Storm
Before you start, you MUST have an Unauthorized Sim Card inserted. Unauthorized Sim Card is a Sim Card that is NOT belong to the provider of the phone. Example: If you have a Verizon phone, you need to insert a T-Mobile Sim Card inside the phone before turn it on.
1. Power on the phone.
2. Phone will said "MEP check failed. Do you want to enter MEP unlock code". Select Yes.
3. "Enter Network MEP code (# left)". Enter the unlock code.
4. Press Enter, you should see "Code Accepted"
5. You need to check Network Connection is set on GSM/UMTS. Menu>Manage Connection>Mobile Network Options and make sure it GSM/UMTS.
6. Once GSM/UMTS is selected. You can now ready to make phone call.
Notice: If the network not working after your phone is fully charged and unlocking process "Code Accepted". You must change from Verizon CDMA network to GSM Global Network a few times, after change from Verizon CDMA to GSM Global 3 times is completed, leaves it on GSM Global Network. Now it should work. (Verizon 8830 World Edition DOES NOT work in USA)
Method 2: Model: 8830, 9500, 9530 Storm, 9550 Storm 2, Telus, Bell Canada Storm
Before you start, you MUST have Sim Card inserted & turn OFF ALL wireless radios, turn the phone sideways so you get the full QWERTY keypad.
7. Type MEPD Note: When typing in MEPD the letters will not appear on the screen, this step open up the personalization on the device.
10. Press Enter (Press the trackball for 8830), you should see "Code Accepted"
11. Press and hold power key to turn the handset off and then back on.
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Cell Phones Logo
vertical colored lines
Hi.If you have a Nvidia Graficcard, it could be it.overheating problem at the motherboard.you need 2 replace motherboard, or reflow, reball graficchip.it's a common problem at Nvidia 6XXX, 7XXX, 8XXX model grafics..
Dec 29, 2013 | Sony VAIO Computers & Internet
I need to upgrade my graphics card for dx2280 mt with external graphics card, can anyone suggest supported graphics card
Hello there mayte!
First of all,what i believe is,your pc has a decent power supply.
I suggest you go on the mid range with absolutely no risk.
Here ill suggest you some.They are categorized on the basis of risk of not working.
Least risk: ATI HD 4XXX series
Medium risk: ATI HD 5XXX/6XXX series
Highest risk: ATI HD 7XXX/8XXX series
Will not work at all: ATI HD 79XX series
I suggest you go with ATI HD7450 which is a decent card with low power supply.
Cheers,
Aldo.
Dec 02, 2013 | Computers & Internet
my geforce 8200 can not play fifa 11
Your graphics card is below the game minimum requirements (see link below) I would guess that this was a Dell, HP or other, and yours is basically a stripped down card with missing features, less memory etc. (which is why FIFA doesn't work) Your game also requires shader model 3.0, which will be present in all retail video cards on the list below.
From my information source site:
" Please note that NVIDIA GeForce 7300,8100,8200,8300 and 9300, ATI Radeon HD3200, HD4350, and Intel / S3 integrated chipsets are below minimum system requirement ."
http://gamesystemrequirements.com/games.php?id=956
If this is a desktop system, you can upgrade your video card to one of the following chipsets (video card series)
"Recommended Chipsets: NVIDIA GeForce® 6xxx series (6800 or greater) NVIDIA GeForce® 7xxx series NVIDIA GeForce® 8xxx series NVIDIA GeForce® 9xxx series NVIDIA GeForce® GTX 2xx series ATI Radeon X1600 (X1600 or greater) ATI Radeon X1800 ATI Radeon X1900 ATI Radeon X1950 ATI Radeon HD 2xxx series ATI Radeon HD 3xxx series ATI Radeon HD 4xxx series.
If you need help choosing a new video card, please repost your question and include the make (Dell, HP, etc. or white box) and model #. If this is a DIY project then please include as much information as possible about the mainboard, what version of windows, power supply, etc..
Once you know what you need I would check out newegg.com for video cards. They will have what you need at the best prices...
Feel free to contact me directly if you would like continued help with this.
Aug 02, 2011 | Computers & Internet
e001 no fifa 11 Problem
DOWNLOAD THE LATEST DRIVER FROM THE MANUFACTUAR S WEBSITE
OR BY USING A UTLITY LIKE DRIVEREASY
(DOWNLOAD)
11. Notes on Video Card Support
ATI Radeon™ X1600 (X1600 or greater)
ATI Radeon™ X1800
ATI Radeon™ X1900
ATI Radeon™ X1950
ATI Radeon™ HD 2xxx series
ATI Radeon™ HD 3xxx series
ATI Radeon™ HD 4xxx series
Please note that NVIDIA GeForce 7300,8100,8200,8300 and 9300, ATI Redeon HD3200 and HD4350 are below minimum system requirement.
Error Message E0001 = This game requires a shader model 3 (or better) card.
If you experience problems, please contact your card manufacturer or chipset vendor to get the latest drivers.
Jun 10, 2011 | Computers & Internet
186 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
