Tip & How-To about Plantronics .Audio 995 Digital Wireless Stereo Headset
Power button not turning on headset
I'm guessing at some point I pressed down too hard on the power button and either broke something or mis-aligned it to what mattered.
If this happens to you:
  1. Plug the headset into the (connected) USB power cord
  2. Blue light comes on
  3. Unplug - Headset should remain on
  • If you leave it plugged in until it turns red (charging) then it will turn off when you unplug it.
  • If your headset doesn't show a blue light or any indication of life, something beyond the power button is wrong.
Plantronics .Audio 995 Digital Wireless Stereo Headset Logo
Why will the doors go up on my garage door opener but not down using the remotes. It works fine using the keyboard.
It is your remote control that is not functioning when the down button is pressed. There is no easy way to test the remote but the small light on the remote should flicker we the button is pressed. If it does not flicker press down hard on the button a few times in effort to get the light to flicker as that will be indicating that transmission is taking place. Dust can prevent good contact with the switch inside the remote and by pressing hard on the button may re-establish contact again. It is however not fail prove as the light can flicker but is still not transmitting to the motor control box. The fact that the keyboard and up function is working indicates that the remote is malfunctioning and need to be replaced.
Sep 21, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
garage door will not close when using the remote or garage door button. it will open, however. it can be forced closed by holding the garage door down. i have had this problem before . i have corrected the situation by pressing one of the other buttons on the remote and then pressing the button that i would normally press to close the door, but this is not working now.
Check to see if your child/animal security beam is working correctly. It is an "Electric Eye" mounted about 12 in off of the floor on two mounting points and one side shoots an infra red beam across to a receiver. These points must be reasonably aligned to flash a beam (cannot see) from one point to another. This beam keeps the door open if it is interrupted . If it is not aligned, then the door opener sees a problem and will not close the door electrically. You must aligned the beam by bending the transmitter or receiver untill you can close the door by the remote. Also check to see if something placed in the garage is not blocking the beam first.
Jan 06, 2011 | liftmaster Garage Door 1/2 Hp
I have htc hd touch,& I can't pass the screen alignment. what should i do to continue normally ?
You need to hard rest your phone... follow the steps
1. With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
3. Release the VOLUME UP and VOLUME DOWN buttons, press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
and still if the prob persist u can mail me at cellphonez99@gmail.com
Dec 02, 2010 | HTC Touch HD Smartphone
aligning cartridges
take out the cartridges from the printer and then clean the contact points on the back of the cartridges with a clean piece of cloth. then unplug the power cable from the back of the printer and then press and hold down the # and 6 button from the front panel of the printer and then while pressing them down plug back the power cable back into the printer.
then insert the cartridges into the printer one by one and then the printer will start align the cartridges automatically.
Nov 04, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
4,506 people viewed this tip
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
