Tip & How-To about Heating & Cooling
Water in Airconditioner
Keep a bowl of water in your Air conditioner room is good for health. Air conditioner will remove all the moisture from the air then it will blow just dry cool air that is not good for health keeping a big mouth bowl of watter will help.
Heating & Cooling Logo
Is my portable lg air conditioner suppose to be blowing hot air out of the back
YES
it works the same as any air conditioner where if you go outside and place your hand at the fan then it will be blowing hot air
In the instructions it should say place the rear near an open door or window or use the hoses to move the hot air out of the room
air conditioner units are basic heat transfer units where they take the heat out of the room and transfer it to the outside and in the process remove the moisture from the air in the room which i turn makes it more comfortable
Mar 14, 2016 | LG Heating & Cooling
Excess water prodution in portable 14000 BTU unit. See below
all a/c units remove moisture from air with cooling coil being cold and room air blowing across coil - depends how humid it is - i have used several different portable units and this seems to be a common problem if it is humid
Jul 03, 2014 | Commercial-Cool 8,000 BTU Portable Air...
I have a sharp window AC unit, model af-609x. does it have a drain hole? there is no water coming out of it, but when we take it out of the window we get soaked from water somewhere inside the unitl
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
Jul 22, 2011 | Sharp AF-M609X Air Conditioner
2002 dodge intrepid air conditioner
How did you check your pressure? A proper way to charge a/c is to evacuate the system, which is removing all the refrigerant, and vacuum it down to remove all moisture. Then recharge with the proper amount of refrigerant.
Or, your drain for the evaporator can be plugged. Have it checked first.
Jun 19, 2009 | 2002 Dodge Intrepid
sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
334 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
