Tip & How-To about Cell Phones
How To Enter Unlock Code Into Motorola Mobile Phones Step By Step Instruction Guides
Model: All Motorola; check below for exception
1. Insert an unauthorized Sim Card and turn ON your phone
2. "Enter Subsidy Code" box appear
3. Enter Unlock Code
WARNING: If one of these messages appears:
- "Contact Service Provider"
- "Tamper Alter"
- "Wait before enter special Code"
- "Contact Service"
It's because you or somebody already enter too many wrong codes, you just have to let the phone ON at these errors message (do not close the phone if V3) and after 40 minutes to 12 hours, the message " Enter Subsidy Code" will appear again.
Model: A1000 and other A series model
1. Click on the Phone icon
2. Enter **057*
3. "Locking Enter Personalization" box appear
4. Enter Unlock Code
5. Press Ok
Model: L6i & L7i (NOT L6 and L7)
1. Press and hold * key and enter 787090
2. "Menu Network" box will appear
3. Select Yes
4. Press OK
5. Will ask for code
6. Enter Unlock Code
Model: All Motorola 3G network model
1. Enter **057*
2. Enter Unlock Code
Motorola CDMA & TDMA
1. Enter 74663# [Menu] [Menu] and you will be asked for a Subsidy Code
Unlock Motorola CLIQ (SIM Unlock) 1. Reboot your Motorola CLIQ with an unaccepted SIM card in.
*If the display reads "Enter Special Code", enter the unlock code and press "OK"
*If the display does not read "Enter Special code":
2. Press and hold the * key until an entry box is displayed.
3. Type *, #, 3, 2, # and press "OK"
4. Enter your Motorola CLIQ's unlock code and press "OK."
5. Your Motorola CLIQ should now display either "Completed" or "Deleted"
Motorola MPX
2. If the phone is asking for NETWORK PIN
3. Enter the NETWORK PIN
4. If the phone is asking for SERVICE PROVIDER PIN
5. Enter the SERVICE PROVIDER PIN
6. Your phone is now unlocked
Network PUK
If the phone is asking for NETWORK PUK: Power on the phone with the original Sim Card in and wait till phone is fully powered on and you have access to menu. Enter *#**364# and press green button. You will get an error message and thereafter, you will see an Engineering Menu:
1. Select Options
2. Select GSM Test
3. Select Send AT command
4. Now you will see a new window Saying "Send AT Command"
5. Enter AT+CLCK="PN",0,"[SERVICE PROVIDER PIN or NETWORK PIN]"
6. Press send
If you get Response "0 []" phone is unlocked. If you get 1 error, then make sure you have typed the code correct and try the other code. Turn your phone off, take battery out. Put battery back in. Power on the phone and leave it for 40 minutes to 12 hours until the message "Enter NETWORK PUK" is gone. Now enter the Unlock Code and 00000000 (eight zero's) as a new password
Service Provider PUK
If the phone is asking for SERVICE PROVIDER PUK: Power on the phone with the original Sim Card in and wait till phone is fully powered on and you have access to menu. Enter *#**364# and press green button. You will get an error message and thereafter, you will see a Engineering Menu: 1. Select Options
2. Select GSM Test
6. Press send
If you get Response "0 []" phone is unlocked. If you get 1 error, then make sure you have typed the code correct and try the other code. If you do not have the original Sim Card or if the original Sim Card is not accepted because you flashed the phone with other firmware, then we cannot help you
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Cell Phones Logo
motorola c168 insert sim problem
Dear:
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Jan 11, 2013 | Motorola Mobility C168 Cellular Phone
Screen all of a sudden is saying "Check SIM" or "Insert SIM" though no trauma has happened to the phone.
This "Insert Sim"(even though already Sim inserted means) or "Sim Error","Invalid Sim",are all problem arises means that Mobile Locked to Some Network,You need to Unlock it to use other GSM Sim Card,You can Unlock the Motorola KARMA QA1 model using the Unlock code at reliable price at this site
http://www.wickedunlock.com/motorola-karma-qa1/rs11wp9/
Jan 19, 2011 | Motorola Mobility Karma QA1 Cell Phone
My phone (A Samsung, model: SGH-A117) is asking for a PUK code and a new PIN code. I have looked on my SIM card, but there is no useful information. Please help.
PERMANENT UNLOCK CODE SAMSUNG SGH A117, T429, T729
Insert ANY unaccepted SIM card in the phone and then turn the phone on, follow the steps in 1 to 4 below to enter all the codes. The phone will states "Wrong card" at the end of step 2 and "network lock deactivated" at the end of step 4 if you do everything right so pls take your time to enter the code or follow the instruction correctly at each step. When entering some of the zeros at steps 3 and 4 your phone may display the zero as hyphen or minus (-), dont worry, just count when entering the zero to ensure you enter just the right numbers of zeros. Now let's begin... 1/ Put any unaccepted SIM card in your SAMSUNG SGH Phone, turn the phone on, it will display "WRONG CARD"
2/ At the wrong card screen, type *7465625*638*00000000*00000000#
3/ Now remove the battery with the SIM card, Put the battery back and turn the phone on again without the SIM card, it will display "Insert SIM card" 4/ At the insert SIM card screen/end of step 3 above type #7465625*638*00000000#
At the end of step 4 phone will show "network lock deactivated" 5/ Now Reinsert your unaccepted card or any other unaccepted SIM card in the phone and enjoy your unlocked phone!
Jan 19, 2009 | Cell Phones
Motorola Razr says insert SIM card when it's already in there
You May Have Fryd Ur Sim Card Did U Try Puttin It In Any Other Phones Besides The Other Model?
Jun 14, 2008 | Motorola Mobility RAZR V3
315 people viewed this tip
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
