Tip & How-To about Cell Phones
Touch sensivity
To increase the touch sensivity clean the touch with a alcohol wipe.the sensivity increases.and the callabiration will be perfect
Cell Phones Logo
How do I mess around with the alcohol content of my homebrewed beer? The last few batches have just not been alcoholic enough.
If you want to increase the alcohol content to your beer, you need to add more fermentable sugar to the yeast. Fermentable sugars include; malt, honey, molasses and corn syrup).
This will increase the alcohol but you shouldn't go crazy as there is a limit to what you can add before you mess it up.
Feb 21, 2013 | Crafts & Hobbies
When I start my treadmill, I have to increase the speed very slowly- otherwise it shuts down and I have to turn it off and back in again. It takes about three minutes of gradually increasing the speed to get up to a jogging level.
This problem coming:
1) Speed sensor : misaligned you must do it, otherwise, you must change it.
2) Please see if some wire is broken, loosen, or pinchen, or maybe clean with alcohol isopropyl 100% for to clean( dust, grease, oil)
3) Motor is faulty: brushes, or winding, or some wire loose, broken, or pinching.
sincerely.
E.CUADRA
Nov 03, 2011 | Proform Exercise & Fitness
game duel only loads half way why
Hi gcecchetti67,
There is a problem with the cd or the lens itself, try cleaning the cd first putting small amount of water on a clean cloth gently wipe the cd not in a circular pattern but in a linear pattern, then test to see if it works. If it doesn't try putting other disk if other disk continue to play well then the problem is in the disk itself if the other disk doesn't play proceed to the next step which is to clean the lens with an alcohol or lighter fluid put some solvent unto a cotton swab and gently rub the lens of the playstation if it still doesnt work try opening the ps and check the lens to look for this 4695d94.jpg
turning it by a flat headed screw driver about 1/8 of a circle also make sure to remember the exact place of where you have been.this is to increase the voltage of the lens to read the disc.
be careful increasing the voltage can permanently damage the lens itsely.Gudluck
Hope it helps,
Thx
Banaple
Sep 06, 2010 | A1 Games Duel Masters: Sempai Legends for...
When trying to load a disk, The computer cant find the disk
First item is cleaning the lens assembly.
Get a CLEAN Q-tip (do not touch the cotton end) and some rubbing alcohol.
Open the Disk tray as you would to load a disk.
Dip the cotton end into the alcohol, then touch to a paper towel for a second. this drains off the excess alcohol.
G-E-N-T-L-Y wipe the surface of the lens. It is mounted on a very flexible mount, and pressing on it can damage it. While wiping, you should not feel resistance. The lens should only move slightly.
Blow on the lens to help evaporate any remaining alcohol. Use a dry Q-tip and repeat the wiping.
YOU MUST REMEMBER NOT TO PRESS ON THE LENS. A LIGHT TOUCH WILL DO.
Retry the disk.
If this does not produce favorable results, you have a hardware issue. If this is the case, please re-post on this form and mention you cleaned the lens per my instruction.
Jan 16, 2010 | Gateway MT6821 Notebook
when I roll the ball to the left, the cursor doesn't go to the left?
change the trackball sensitivity
Steps :
1. Click Menu Key
2. Go to options, under that select Screen/Keyboard
3. scroll down you will get track ball settings
Horizontal sensitivity
Vertical sensitivity
increase the sensivity to 100 then you will be able to roll track ball,it will work fine....
Oct 30, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
199 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
