Tip & How-To about GE Advantium 120 Convection/Microwave Oven
How To Change The Bulb In An Advantium 900 Watt Microwave
You'll need to open the door, and remove the screws that hold the microwave face to the cabinet face.
Next, you'll need to remove the microwave from the enclosure. Remove the metal shroud that encases the microwave, and the bulb may then be replaced. Reversing the process gets you back to where you started.
After the second time of pulling the microwave out, I measured and cut a hole in the sheet metal shroud, larger than the access to the light fixture. I bought a metal electrical box cover, and used sheet metal screws to completely cover the hole. This allows me to slide the microwave out about 6" to access the light, instead of the lengthy process of removing the microwave entirely. If you decide to do this, I recommend that you mark the sheet metal while the shroud is loosely fit on the microwave, and cutting your hole away from the microwave, to avoid getting metal filings into the microwave.
Your bulb is a 120 volt halogen, 35 watts with a GY8.6 base. I bought mine at Lowe's, and their item number is 15797, manufactured for Bright Effects. When installing the new bulb, be careful not to touch the bulb, as the oil on your fingers is enough to degrade the bulb, and it will not last as long as it should. Instead, wrap the bulb in toilet paper or a paper towel, leaving the terminals on the base protruding.
Sorry for the bad news, but glad that I could offer a better alternative. By the way, a technician will do the same thing, without the hole, for about $200.
GE Advantium 120 Convection/Microwave Oven Logo
How to remove the old Tappen microwave oven model 56-2891 under the cabinet?
open the cabinet door above the microwave there should be four screws going thru bottom of the cabinet shelf holding it on to cabinet have a helper hold the microwave as you unscrew it
Dec 12, 2010 | Tappan Microwave Ovens
how to remove sharp 1480 microwave from the wall
If this is a built in mounted under an overhead cabinet, Just open the above cabinets and there will be 2 long screws facing downward that hold it in place, if it is a built in that is framed in then you will need to remove the frame and the brackets behind the frame that are holding it in place and then slide it out.
Aug 26, 2010 | Sharp R-1480 Microwave Oven
replace the buttons on a kitchenaid microwave Khhs179lss-5
First, you need to uninstall the microwave (MW) from the cabinet by removing the screws that hold it in place at the top. Open the cabinet doors above the MW to locate the screws.
You will need someone to help you at this point in removing the screws and dropping the MW down. Be sure and unplug the MW before you remove the screws.
Next, you need to take the cover/shell off by locating and removing screws A/R. They are mostly across the back and side bottom.
From there on out, you should be able to methodically find and locate the various fasteners that will get to the button pad.
Dec 16, 2009 | KitchenAid KHHS179LSS Convection /...
I can't find bolts or screws that hold the unit in place. I need to remove the microwave in order to install new one.
HI there,
Here's HOW;
  1. Remove the face plate above the door.
  2. There were 2 bolts in which you will need a screw driver to loosen it
  3. This bolts go all the way to the back of the microwave.
  4. You still need to remove the one - three screws that's above of the cabinet. You may have to jar it loose if it still stuck.
Hope this helps.
Let me know for further instructions.
Aug 04, 2009 | Microwave Ovens
Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Jan 31, 2008 | Microwave Ovens
2,487 people viewed this tip
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
