Tip & How-To about Computers & Internet
Dell Vostro 1000 Bios - Flash Failure
I attempted to update the BIOS on my Vostro 1000 to cure the bad battery message. My original BIOS was 2.6.1 and I intended to update to 2.6.3.
I could not flash under Windows 7 so I installed XP but the flash failed half way through.and the computer did not power up again. All that happened after I pressed the power switch was the light came on and the CD drive shuffled a couple of times. No screen illumination.
Various posts were scanned but no solution found until my buddie came up with the following sequence.
Get the file posted in this link on a computer running XP
http://hotfile.com/dl/113520903/05689ed/VOSTRO1000_CRISDISK.ZIP.html
To Create a Crisis Recovery USB you must use a Win XP system
Note: Running XP through compatibility more in Win 7 will not work
1. Insert Blank USB Drive
2. Open "CRISDISK" folder
3. Open "WINCRIS" application
4. It should detect the USB Drive
5. Click "Start" Button WINCRIS should create the USB recovery drive
6. For Crisis recover, be sure to Power drain system.
. A. Remove Battery
. B Depress power button for 10-15 sec.
7. Insert USB drive into USB port of the Dell.
8. Hold END button while plugging in power cord in system
9. Continue to hold END and depress and release the system power button.
10. Continue holding END until USB drive begins to flash and a single beep is heard.
11. System may remain blank as it enters recovery mode - Anoying Beeping will be heard - Beeping will stop and FANS will function Another series of Beeps will be heard
12. System should complete recovery in 5-10 min. If system has not powered down in 15 min, power down by pressing the power button
This worked for me and as a bonus I do not have the battery error message anymore.
Computers & Internet Logo
When try t charge my battery in my Vostro 1000, I get a message " The battery cannot be identified the system will not be able to cahrge the battery
Try this first:
Use up the battery until the the screen would black out. Afterwards, reboot the laptop ( without using the AC adaptor) and the system will warn you of low battery - to press F1. After pressing F1, plugged the AC adaptor back and try rebooting.
If the above does not work, there is a Bios update from Dell that suppose to fix this problem.
Oct 20, 2010 | Dell Vostro 1000 Notebook
The battery is not identified the system will not charge battery
I had the same problem with my 2 years old vostro 1000. I updated the bios and problem solved.
Sep 03, 2009 | Dell Vostro 1000 Notebook
Dell Vostro 1000 shut down and won't turn back on
nope, it is your dc power regulator board. you will note this happens if the battery is in or out of the laptop. that is the key test. some regulators are on the main board and some are seperate for this reason. I think the vostro though is on the main board. A little board re-work will resolve this issue after replacing some components, but this is way beyond a home user's ability.. trust me on this. Sorry for the bad news. Thanks!
mrstan
Aug 29, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
dell laptop cannot identify battery
Update the bios. I did it and problem solved.
Jul 03, 2009 | Dell Vostro 1000 Notebook
Update Dell Vostro 1000 BIOS now wont turn on, nothing on display
You may be in for some trouble, a failed bios update isn't always an easy fix. if you can find the cmos battery try to remove that for a few seconds. you will also need a disk version of the bios, download that from dell on another computer and copy it to floppy or cd and see if you can boot to that and reinstall the bios.
when you press the power button what happens, does it light up and run the fan? Nothing appears on the screen?
Dec 29, 2008 | Dell Vostro 1000 Mobile AMD Sempron...
2,075 people viewed this tip
David Payne
David Payne
