Tip & How-To about Office Equipment & Supplies
Error P22 CANON PRINTERS MP 240-250-260-270-280
If appears error P22 at this printer CANON MP 240-250-260-270-280 means you need to replace first the scanner,if the problem persist you need to replace the logic board.
error code p22
P22 (Scanner error)Cause: The scanner is not workingSolution:1. Replace Canon MP250 printer scanner.2. Board Replace Canon MP250 printer
Better TO buy a new one..
Http://www.tech911.biz
Mar 22, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
mp258 error code p22
6. P22 (Scanner error)Cause: The scanner is not workingSolution:1. Replace Canon MP250 printer scanner.2. Board Replace Canon MP250 printer
HTTP://WWW.TECH911.BIZ
How do I fix error P22 on Canon pixma mp495 printer?
Error P22 is a scanner error.
The only solution I can find is to replace the Scanner Unit and Logic Board.
Jan 09, 2011 | Office Equipment & Supplies
Canon MP 648 suddenly appeared a message: ERROR 5012, then after the power off and turned on again appears ERROR 5050. Printer error has occurred. TURN POWER OFF THEN BACK ON AGAIN. SEE IF THE PROBLEM MANUAL persist. I already follow the message, but the result is the same. What should I do.
From the service manual, both errors relate to the scanner unit:
[5012] An error occurred in the scanner FB motor.
(1) Cable connection (2) Part replacement: - Scanner unit
[5050] The AFE was faulty.
I don't know if the following YouTube video will help, but you could watch and see if it applies to your printer.
Error 5011 and 5012 Printer Canon MG 2570 MP 237 MP258
Feb 09, 2018 | Computers & Internet
2,211 people viewed this tip
k24674
jasbo
jasbo
