Tip & How-To about Cell Phones
Nokia 1208,1029 restarts when opening ring tone
If we try to open the ringtones ,the phone restarts.its a small software complaint .it can be resolved by restoring to factory settings
Cell Phones Logo
My ringer is not working on my I phone 4S phone I am not hearing the phone when it rings and I have volum turned up all the way
There are a few issues that could cause your iPhone to be silent when it should be ringing.
First, on the side of your iPhone there is a switch just above the volume buttons. If you can see an orange strip in this switch, toggle it upward (toward you when the display is facing you).
If this does not resolve your issue, go to the Settings app and tap on the Sounds section. Make sure the Ringer and Alerts volume slider is all the way to the right. Also, tap on Ringtone and then any of the Ringtones in the list. If you cannot hear the ringtone when it is tapped, it is most likely an issue with either the software or the speaker.
If you are able to hear other sounds from the speaker on your iPhone, but not the ringtone, it is either a software issue or the mute switch (the side switch from the earlier step) has stopped responding. Try hard restarting your iPhone by holding the power button on the top of it until you see the Apple logo. If the issue persists, back up your iPhone to iCloud or your computer and visit an Apple Store. They will most likely need to restore (erase, hence the need for a backup) your iPhone to factory settings. If that does not fix the issue, then it is a hardware problem. All software repairs at Apple Stores are free, but hardware repairs may cost money if your iPhone is out of warranty.
Instructions on how to backup and restore your iPhone, if necessary: http://support.apple.com/kb/HT1766?viewlocale=en_US&locale=en_US
I hope this helps. If you have any questions about the instructions above, let me know and I'll do my best to help.
Oct 31, 2013 | Apple Iphone 4s I Phone 4 S Factory...
No music or ringtones
Dear Brother,
As you said you Did Restore Factory Settings Well.So there is no chance of Problem for Software.It is Mostly seems to be a Complaint of your Hardware .You just Type *#7370# & enter Phone Code to Hard Reset(If already done Ignore it)
  • Hardware might be speaker (Buzzer)
  • You need to Change Speaker
  • Or Problem with Audio IC /Some Supporting Components
  • Disassemble your handset and Change it CAREFULLY only if you able to do yourself
You cannot Activate or make Loudspeaker/ Speaker Phone Now ...Right...??!!!!
Hope this Helped you....Thanks for Contacting FixYa......
Apr 20, 2010 | Nokia E63 Cell Phone
I have a Nokia 1661-2b and all of my ringtones hae
restore ur phone follow me :- press menu + setting+restore factory default + security code phone will restart and it is now ok
Nov 26, 2009 | Nokia 1661 Cell Phone
499 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
