Tip & How-To about Computers & Internet
Disable low disk space message
  1. Click Start, click Run, type regedit, and then click OK.
  2. Locate and then click the following key in the registry: HKEY_CURRENT_USERSOFTWAREMicrosoftWindowsCurrentVersionPoliciesExplorer
  3. On the Edit menu, point to New, and then click DWORD Value.
  4. Type NoLowDiskSpaceChecks, and then press ENTER.
  5. On the Edit menu, click Modify.
  6. Type 1, and then click Ok.
(make registery backup)
Note There is a registry value you can set to disable this feature. To disable low disk space checks, follow these steps, log off, and then log on again: Follow these steps, and then quit Registry Editor:
Computers & Internet Logo
cd and dvd drivers not working
If the drive is showing an error (or is missing) in device manager, do the following:
Start Registry Editor (Start, Run and type in regedit then click O.K)
Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK.
Locate the LowerFilters value under the same key in the registry:
Quit Registry Editor.
Hope this helps
May 02, 2009 | Acer Aspire 5315 Notebook
burner
If it does not show up in device manager do the following:
Apr 30, 2009 | Acer Computers & Internet
my dvd driver missing from the system,i can't use it
Apr 30, 2009 | Acer Aspire 5610-4648 Notebook
cant play or burn cds
Apr 25, 2009 | HP Compaq Presario C500t Notebook
167 people viewed this tip
David Payne
David Payne
