Tip & How-To about Cell Phones
Mobile trick
Using this you can get your sim card nos very easily.By pressing y + # (where y is any number) will show the telephone number stored in that particular location.
yes it works for example if u type
10 in idle mode and then pressing "#" , it will show the 10th number stored when the number are entered in your phone-book.
try it
Cell Phones Logo
Describe your Cellular Phones Problem what is a sim card
A sim card, also known as a subscriber identity module, is used by GSM cellular telephone subscribers. It is used to store data such as phone number, network authorization data, personal security keys, contacts and stored text messages. They are typically placed in a slot underneath the phone's battery.
Sep 11, 2011 | Cell Phones
Cannot seem to store phone numbers on the phone (Hundai HDT-L12). Have lost the manual, but looks as if it should be simple. However, I just can store 1 number only.
might be ur phonebook memory is full thats why it is not storing the nos or u have changed setting of phonebook to save a contact in sim card & u have to search no. seperately in sim card
If this solution is not satisfactory then write to me again with a full clarification
Jul 04, 2010 | Lands Phones
caller id
try and master reset your phone back to the default.....
menu/settings/initial setup/master reset
Jan 10, 2008 | Motorola Mobility RAZR V3
ConairPhone SW324WCS
I just had same problem and went conairphone site and found model sw322 that looked about the same. I downloaded the manuel and it worked for my phone. Here it is. MEMORY FEATURE To Program Your CONAIRPHONETM telephone is equipped with 10 memories for programming your most frequently dialed telephone numbers. You can store up to 16 digits in each of the numeric keys (0 through 9), by following the steps outlined below: 1. Lift handset (releasing hook switch). 2. Press and release STORE key. 3. Press the keys for the telephone number you wish to store. 4. Press and release the STORE key again. 5. Press the keypad number (0-9) you want that telephone number stored in. 6. Your number is now stored. 7. To change a stored number, repeat the same process. The new number will store over the old stored number. A Memory Index card is provided for your use in writing down the person?s name. To Retrieve Memory Numbers Keypad Memories: To retrieve numbers stored in the keypad, pick up the handset and press the MEM (Memory) key. Then press the keypad number (0-9) which stores the telephone number you want to dial. Your call will be automatically dialed.
Jul 12, 2007 | Conair SW324WCS Corded Phone
192 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
